06-18-2018, 04:28 AM | #1 |
Rep 3,068
F30/31 Ride height
Cleaned the car today, it was on a flat level surface and I looked at the new tyres fitted & checked pressures etc. I noticed that one side seemed lower that the other so I set about with a tape.
I measured from the bottom of the alloy rim through the wheel centre to the underside of the arches both back and front. Result was that the drivers side sits 10/11mm lower than the passenger when comparing same dimensions from the passenger front/rear. I even checked the front splitter underside to road dim and that too varied by 12mm side to side. Has anyone else had this ? the car is a F31 330d so some weight up front but wouldn't have thought that would make any difference. I only ask because i'm now thinking of ACS springs / shockers and 10mm or so could be critical for my front splitter staying intact ! Anyone found similar ? Thanks |
06-18-2018, 04:59 AM | #2 |
Rep 114
I have long battled with BMW customer service and also my local dealer over the rear ride height of my F31. On a proven flat surface (F3 racing platform) my car sits 10-11mm lower with a full tank of fuel on the o/s rear compared to the n/s rear.
After protracted talks I eventually got out of BMW that the factory tolerance is 10mm and they will not accept that my car is outside of that parameter and will not do anything about it. I have had excuses that it it is because of the fuel tank is a saddle tank and that fuel may sometimes have a greater quantity on one side of the saddle than the other, that the battery sits on the o/s rear, that the car is set up for left hand drive. All these excuses are just bollocks! I have never owned any car before that did not sit level at the rear. So I am afraid that unless you can get more success than me you are just going to have to live with the fact that BMW cannot produce a car that sits level!! Last edited by shoestring; 06-18-2018 at 05:04 AM.. |
Alscoob2119.00 |
06-18-2018, 05:11 AM | #4 |
Rep 3,068
Thanks for that info guys, maybe a set of ACS springs might help, but sound like coilovers is the only remedy if that is so. Do't think Ill be going down that route though.
06-18-2018, 05:49 AM | #7 |
Rep 8,500
Yes, have had this problem in the past. Really annoyed me, and not easily corrected in OEM form.
It's one of the benefits of height adjustable coilovers and corner-weighting as part of the setup, but I appreciate it's an expensive option.
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
HighlandPete6658.50 Alscoob2119.00 |
06-18-2018, 06:02 AM | #8 | |
Rep 15,858
Assuming a BMW is perfectly balanced for weight, side to side, for LHD builds, RHD conversion will change the loadings unless BMW make L/H and R/H springs to adjust for the changes. Aftermarket will be the same unless the springs are set for L/H and R/H sides. Adjustable suspension is the only way to get a perfectly measured set up. For example, models with the battery mid position in the boot will have less of an issue, than a models with a battery put to one corner. An issue for measuring, (even on a known flat surface), how is the car weighted? Even the driver positioning the car and just getting out may not give the exact ride height. Rebound on exit may be less on the driver's side, due to some stiction in the components. Car will need 'rocking' to even out the loadings. |
Alscoob2119.00 |
06-18-2018, 06:44 AM | #11 |
Rep 3,068
Interesting information.... thanks
Guess that as I will likely change the car next year, it's not really worth the expense of doing a 'proper job' and spending a fair sum of money at this point to correct it. I like the F31 size /appearance etc., so if I had another potentially could transfer the parts, or some of them, but there is no guarantee that I would have another, so I'll just live with the tolerances |
06-18-2018, 06:47 AM | #12 |
Rep 3,068
06-18-2018, 07:48 AM | #13 |
Rep 3,432
I am always genuinely surprised when folks raise this issue (as they do from time to time) as many cars on our roads have been just like this for donkey's years... You can see it every day just following folk around on the highways... and cars have always been built to tolerances...
CAR HISTORY - Golf GTI 245 - F30 340i M Sport - F30 330d M Sport MPPK - F30 320d Sport - 997 Gen2 GT3 - 987 Cayman S - 986 Boxster S - Ibiza Cupra - Polo 16v - E30 M3 (Official GB import) - Integra 16v - Mk2 Polo S - Mk1 Golf C
06-18-2018, 07:57 AM | #14 | |
Rep 3,068
06-18-2018, 08:19 AM | #15 |
The artist formerly known as AC Schnitzer UK
3609
Rep 4,518
It's normal, and it's not just for BMW. I've had a £100k Porsche here that was the same, 10mm lower on the right front and back. Our tech tells me that back in the E36 days BMW offered different height spring pads to help. I wouldn't know, I was a small child at the time.... AC Schnitzer springs won't make any difference to the umm..difference.
Alscoob2119.00 |
06-18-2018, 09:16 AM | #16 | ||
Rep 3,432
If you can find an old Renault 5.. have a look at the rear wheels on both sides... after a while, you will notice that the panels in front of them are different, side to side... because one rear wheel is further forward than the other, due to the design.... many folk never spotted that...
Alscoob2119.00 |
06-18-2018, 10:01 AM | #17 | |
Rep 3,068
