06-17-2018, 02:33 PM | #1 |
Rep 922
Do spacers affect the airflow?
Before fitting the spacers I never used to hear any "wind rustle" (not whistle but more the sort of noise you expect when you open your window slightly) at motorway speeds.
Since fitting them, I notice this noise a lot more and it's much more noticeable when you have a wall or a high sided vehicle close to you. I cant find anything loose around the doors, can't see any obvious defect in the seals and scratching my head like crazy the only change I can put it down to is the spacers. Has anyone else noticed this? Or is the culprit something else and I've just picked the wrong victim?
Coding. LED Front Fogs. DIY Driver Glovebox. KW Street Comfort. 15mm Rear ARB. Tarox SS Brake Lines. Motorwerks Remap. DIY Rear 12v Socket. M Performance Discs. Tarox Strada Pads. Spacers (10mm & 12mm). Head Unit USB Cable. Rear Diffuser. Rear Light Tints. Non RFTs.
06-17-2018, 02:50 PM | #2 |
Rep 8,498
I noticed a distinct difference in sound when the M Sport drilled discs were installed when I had the MPPK fitted a couple of years ago. A distinct hissing/whistling noise, especially if there was a hard surface near the car to reflect the sound.
It went completely when I installed the StopTech BBK - slotted, not grooved, discs. I haven't noticed it since. Spacers were installed with both.
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
06-17-2018, 03:27 PM | #3 |
Rep 922
You think the dimpled areas of the M Performance discs are the cause?
Because the other part of them are slotted, same as your StopTech?
06-17-2018, 04:34 PM | #4 |
Rep 8,498
It's the only link that I could find. Dimpled discs = noise; slotted =- quiet (as far as I've noticed).
