06-17-2018, 08:43 AM | #1 |
Rep 922
Cable from head unit not actually charging
A few days ago I did the mod where you connect a cable to the back of the head unit, through the dash and out beside the right vent.
Connected it up to my phone today for it to charge, was connected for 20 mins but the percentage stayed at 39% the whole time. Anyone else have this problem? Could this be because I bought a cheap cable?
Coding. LED Front Fogs. DIY Driver Glovebox. KW Street Comfort. 15mm Rear ARB. Tarox SS Brake Lines. Motorwerks Remap. DIY Rear 12v Socket. M Performance Discs. Tarox Strada Pads. Spacers (10mm & 12mm). Head Unit USB Cable. Rear Diffuser. Rear Light Tints. Non RFTs.
06-17-2018, 09:30 AM | #2 |
Rep 785
Drives: 2018 F80 M3 CP YMB
Could be - or it could that usb wasn't designed with iphones in mind - iphones are very fussy - my son's new Micra wouldn't charge iphones on its usb - any other phone was fine - dealer had to replace the whole wiring loom to fix it under warranty! I guess first thing is to make sure the lead you are using works in the armrest usb?
Current: 2018 F80 M3CP YMB. Previous: 2015: F34 335d GT M Sport+; 2012: F07 535d GT M Sport; 2008: 335d SE; 2005: 530d; 2003: 330d; 2002: 330i; 1999: 523i
06-17-2018, 09:50 AM | #3 |
Rep 922
I'm using an Android.
The cable that comes from the back of the head unit has the female USB end, all obviously I have a USB from that then into my phone. This second cable (with the usb and the the end fitting into my phone) works perfectly. |
06-17-2018, 10:41 AM | #4 |
Rep 785
Sounds like a dodgy extension lead then - try plugging directly into head unit with your known working lead and also try using the extension lead in a normal charger just to prove that is the issue - I don't know about the socket in the head unit so can't comment on it's use but at least that will prove if your leads are ok...
06-17-2018, 11:42 AM | #5 |
Rep 922
But if it wasn't working then the percentage would go down (I had GPS location in with Google's Maps navigation running).
My guess is the amp supplied is too low that it's not charging, but not low enough that it loses charge. The extension is fine, so I'm assuming it's the main cable. |
06-17-2018, 12:18 PM | #6 |
Rep 32,881
It’s probably because it has got enough amps for your phone, my iPhone charges fine from it but some of those Android phones are more like small tablets. Which one is it and what amperage charger is it supplied with?
06-17-2018, 12:26 PM | #7 |
Rep 922
The funny thing is, it charges fairly quickly from a socket at home which provides 0.5A (when every other phone I tried on it would charge really slowly from that exact socket), so I expected this to be decent charge.
It's a OnePlus 5T. |
06-17-2018, 01:15 PM | #8 | |
Rep 32,881
Probably worth trying a decent quality cable in the car? Last edited by teaston; 06-17-2018 at 01:22 PM.. |
06-17-2018, 02:25 PM | #9 |
Rep 922
There is something about this type of battery that allows it to charge faster than most others. It's not a LiIon battery but a LiPo battery (from my limited understanding, there is a difference in the chemistry between the 2 types).
Ok so I tried it again, this time time with everything switched off (GPS, Bluetooth etc) except mobile data connection, screen off (my first try was with screen off since I was Google Maps for navigation). After 20mins I managed to get 6% charge, which is what I would roughly expect for a low amp draw. I'll keep experimenting but I suspect if I want it to actually charge "properly" whilst also using it as a SatNav device then I will need to get a higher quality cable. Thanks for the replies guys.
06-17-2018, 03:07 PM | #10 |
Rep 785
Does it behave the same plugged into the armrest usb? At least that will tell you if there is a chance you are losing anything from the cable from your head unit- plan b could be to use the socket in the passenger footwell with a usb converter as that way you should get 2A or more?
06-17-2018, 03:21 PM | #11 |
Rep 922
I'll try experimenting around.
06-17-2018, 03:31 PM | #12 | |
Rep 32,881
06-18-2018, 03:00 AM | #13 |
Rep 8,500
I use the head unit / USB extension lead which I mentioned in a previous reply, plus an Amazon Basics Lightning cable (the plastic moulding on the male end is exactly the same as Apple cables, and is a very good fit into the Brodit bracket).
Charges my iPhone SE without any problems. I suspect you've got a problem with one of your cables.
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
06-18-2018, 03:14 AM | #14 |
Rep 922
I bought a cheaper cable from eBay (that goes from the head unit), I guess I shouldn't have.
