06-03-2018, 01:04 PM | #1 |
Rep 88
Headlight condensation
My headlight has been getting a lot of condensation the past couple days and now my headlight went out. Is there a way to seal the headlight better or do I just need to buy a new one.
06-03-2018, 01:50 PM | #3 | |
Rep 24,650
Check housing sealing and check if the housing is closed properly...
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
06-03-2018, 03:05 PM | #4 |
Rep 88
Is there a video that shows the housing and seals. I want to make sure they are probably fitted. I used the hair dryer method yesterday and it worked. Today it came back just as bad and the headlight blew. So I'm not sure where it got worse.
06-07-2018, 09:58 AM | #5 | |
Rep 153
06-07-2018, 01:25 PM | #7 |
Stop the hate, get a V8
3850
Rep 8,625
Most headlights have a drainage tube/valve. If that gets damaged, dirty, or blocked, moisture will build up.
Past: 2011.5 M3 sedan ZCP |
06-07-2018, 01:29 PM | #8 |
Rep 1,881
my passenger headlamp showed some condensation after my last wash as well, but havent seen anything since. guess its time to check all the seals.
06-07-2018, 01:41 PM | #9 |
Rep 1,930
06-25-2018, 12:32 AM | #11 |
Rep 189
It sounds trivial, but make sure the little door on the fender liner is sealed well.
The one in front of the tire where you would reach through to change your bulb. Had crazy condensation in my headlight of my last car because one was missing and during car washes (with pressure washer) it would get moisture in through that. Worth a check. |
07-01-2018, 10:00 AM | #12 | |
Rep 88
11-24-2018, 06:49 PM | #13 |
Rep 744
bumping this - ran my car through the wash and the driver's side headlight has a ton of condensation in it. It's going to get very cold tomorrow, what's the fastest way to remove this without taking the bumper & headlight off? the only bulb i have easy access to is the H8, should i pop that off and just run a hairdryer at the headlight?
i think the h8 may not have been perfectly sealed, which is how so much got in there in the first place |
12-02-2018, 06:05 PM | #15 |
Rep 744
thanks - hairdryer did the trick, and surprisingly well. there was condensation covering every surface inside the headlight when i started. 45 minutes later, dry. now to only stop it from happening in the first place...
12-02-2018, 07:45 PM | #16 | |
Rep 1,036
https://www.m3post.com/forums/showthread.php?t=1548304
Akrapovic | AngeliBright | APEX | Hankook | IND | JRZ RS1 | Macht Schnell | Mode Carbon | Vorsteiner |
12-02-2018, 08:16 PM | #17 |
Rep 1,458
Drives: 2023 G81 M3 Touring
Friend bought a 2009 M3 about six months before I did, spent AU$4000 on a new headlight as the original was rusted beyond repair.
12-03-2018, 08:42 AM | #18 | |
Rep 744
When you say new covers, is that the top, or the entire clear housing? |
12-04-2018, 11:01 AM | #19 | ||
Rep 1,036
