Adjusting wastegates on N54
05-23-2018, 05:19 AM | #1 |
Rep 2,343
Hi,
does anyone know if you can access the wastegates easily from underneath the car with the protective trays off? Will the subframe or other bits be in the way? I've got some GC turbos. Sound like the wastegates are rattling at low throttle. Like 20%. On the JB4 I've tried adjusting the default wastegate position with no improvement. Quite possibly the wastegate duty cycle at that throttle has a slight closure of the wastegates. My RB heat shield means accessing the wastegates from the top is not possible. Could be the connection between the exhaust and down pipes or similar vibrating. The exhaust flapper valve is not loose or noisy. Anyway if the wastegates can be checked I'll start with those first. Thanks
GC Turbos, FBO, JB4, DCT, Port Meth injection, BMS Charge Pipe, NGK plugs. EBC brakes and pads, LED Angel lights, LED foglights, LCI rears OCC, Braided brake lines. Custom Diff Lockdown Kit, VTT inlets, TMAP, stage 2+ fuel pump
11.79@119mph (stock turbos) 11.74@129mph (GC Turbos) |
05-23-2018, 06:32 AM | #2 | |
Rep 6,968
Drives: 2007 Black/Black 335i e90
05-23-2018, 08:39 AM | #3 |
Rep 2,343
further reading it looks like you have to get the down pipes off.
Will have to live with it for now. Just went for an MOT. 2 front tyres starting to cord on the inside. So annoying. Thought the tracking was out. Took it to a place who couldn't get their equipment under my arches. Only planned running these wheels for a while until going back to the summer set. Destroyed them on the inside. Lesson learned. Dang it.
05-23-2018, 09:13 AM | #4 | |
Rep 129
Drives: Silver 2007 335xi
//2007 335xi // Titansilber Metallic, Black Dakota Leather w/ Nav, Auto, Logic 7
// 1992 318i // Black Exterior, Tan Interior, 5 speed, Aftermarket Radio w/ 2 10" JL w3 v2 subs and Cadence Ultradrive 750W RMS Amp |
05-23-2018, 11:37 AM | #5 | |
Rep 2,343
