N54 Parts
05-03-2018, 02:22 PM | #1 |
Rep 712
N54 Parts
I have a stage 2 boost concepts fuel pump with less than 3k miles. Comes with everything including the fuel level sensor and the top hat. The top hat has a little corrosion around the top from my old rusted tank ring. But still works 100%. Also have a AIC1 port injection controller. It is missing the front cover but it works fine. I used it until I upgraded to the newer version. This one uses boost reference from the manifold instead of map sensor voltage. It comes with a long hose to hook into your manifold. I also have some meth kit parts such as a devils own 2.25 gallon race cell tank. It has a level sensor and a cooling mist pump hooked to it. I also have a hobbs switch, solenoid and a relay to it. All you would need is hose and nozzle. Pump: 250 AIC: 150 Meth stuff: 150 This is without shipping. PM if your interested and I can get some pictures. |
