BMW M3 Forum (E90 E92)
      03-17-2018, 08:36 AM   #1
Route 16
I got lei'd
Route 16's Avatar
Philippines
841
Drives: '10 E90 M3
Part find help for intake elbow (rubber sleeve/coupler)
I’m trying to find another rubber sleeve/coupler for the side closest to the plenum. AFE’s sleeve looks wider which is what I need. Agency power’s is too narrow and would slip off. I’ve looked at some auto stores and Home Depot.
I’m betting a plumbing store might have one but if anyone knows a website to refer too.
It would be 20” diameter, 2” wide and flexible
      03-17-2018, 08:43 AM   #2
roastbeef
roastbeef's Avatar
Drives: E92 M3
afe won't sell you one?
Instagram; @roastbeefmike
      03-17-2018, 09:12 AM   #3
EJT86
EJT86's Avatar
Drives: 2018 M2
  [0.00]
2018 BMW M2  [0.00]
One of my condoms would fit easy just trim it down I’ll sell you one for $5
Route 16840.50
      03-17-2018, 09:50 AM   #4
Pig Farmer
Drives: E92M
Yeah, those female condums are pretty big.
Route 16840.50
      03-17-2018, 10:34 AM   #5
Route 16
I got lei'd
Route 16's Avatar
Philippines
841
Drives: '10 E90 M3
this set up is one from agency power, it's a discontinued part
      03-17-2018, 10:59 AM   #6
EJT86
EJT86's Avatar
Drives: 2018 M2
  [0.00]
2018 BMW M2  [0.00]
WTH is a female condom lol
      03-17-2018, 11:02 AM   #7
Route 16
I got lei'd
Route 16's Avatar
Philippines
841
Drives: '10 E90 M3
here's another device, imagine placing this on full suction
but for serious, need help finding a part
      03-17-2018, 11:05 AM   #8
roastbeef
roastbeef's Avatar
Drives: E92 M3
AFE makes a similar part... it's going to be the same size as the plenum no matter what else it is tightening up to.
      03-17-2018, 12:00 PM   #9
EJT86
EJT86's Avatar
Drives: 2018 M2
  [0.00]
2018 BMW M2  [0.00]
Look into the macht Schnell ones I’d call these companies direct and say you bought their kit a while back but lost the part
Home Depot prob would have something just not that big. Maybe a pool supply store idk
      03-17-2018, 02:03 PM   #10
pbonsalb
Drives: 18 F90 M5, 99 E36 M3 Turbo
Just determine the round diameter and see if a silicone coupler is available in that size. They are usually 3-4 inches wide. Like for a diesel truck turbo intake.
      03-17-2018, 02:06 PM   #11
EJT86
EJT86's Avatar
Drives: 2018 M2
  [0.00]
2018 BMW M2  [0.00]
4” is def too small and He said 20” diameter which I assume he meant circumference which would be about 6 1/3”
      03-17-2018, 05:51 PM   #12
pbonsalb
Do you think he measured exactly? Do you think he measured ID or OD?
      03-17-2018, 06:07 PM   #13
roastbeef
roastbeef's Avatar
Drives: E92 M3
you're chasing a wild goose trying to find a non-intended solution. just buy someone's aftermarket intake coupler and be done with it.
      03-17-2018, 07:10 PM   #14
EJT86
EJT86's Avatar
Drives: 2018 M2
  [0.00]
2018 BMW M2  [0.00]
No clue I have the stock one so never needed to measure. I’d guess the od since that’s easiest and his is thin walled carbon so prob not much diff. OP if you have the stock one still you can cut the ends off that and try. Or just use some bead seal and use the skinny one you think will slip off
      03-17-2018, 07:37 PM   #15
pbonsalb
Should measure ID of the existing rubber. If it is 6.00 or 6.5 or 7 or 7.5 or 8 inches you can easily find a coupler. If you need quarter steps it will be harder to find.
http://www.intakehoses.com/mm5/merch...egory_Code=SS8
http://www.hps-siliconehoses.com/cat...gory/view/id/8
      03-18-2018, 12:45 AM   #16
Route 16
I got lei'd
Route 16's Avatar
Philippines
841
Drives: '10 E90 M3
Yeah circumference, diameter would be 10”
But it’s the weekend, I’ll try either company (afe/ms) if they have the part
I’ll look at a jacuzzi store too
      03-26-2018, 08:08 PM   #17
Route 16
I got lei'd
Route 16's Avatar
Philippines
841
Drives: '10 E90 M3
AFE came through, fits perfect now
CF elbow with a BMC filter=winning
      03-26-2018, 08:25 PM   #18
pbonsalb
Stretch it into a perfect circle and measure the inside diameter.
      03-27-2018, 03:15 AM   #19
Route 16
I got lei'd
Route 16's Avatar
Philippines
841
Drives: '10 E90 M3
you need the part #?
AFE sells it for $20
      03-27-2018, 06:37 AM   #20
pbonsalb
No just curious whether it’s a standard size coupler or not.
      03-02-2021, 04:37 PM   #21
LTeezy
Drives: e92 M3
Interested in getting AFE couplings for my CF intake elbow! Pls PM how you were able to get a set! Thanks!
      03-03-2021, 08:55 AM   #22
Route 16
I got lei'd
Route 16's Avatar
Philippines
841
Drives: '10 E90 M3
Here's what I found in my email
05-01262 Coupling, Silicone Hump: 6-1/4 1 EA 20.00
m3post
