BMW M3 Forum (E90 E92)
BPM
      03-04-2018, 05:24 PM   #1
Spun Crankhub
Drives: 15 F82 *SOLD*
Refinishing my red Stoptech St60/40 in red, black logos
Even though my car currently has a black front St60 I have been wanting red front and rear calipers, so when I got the opportunity to buy a used set of St60/40's in red, needing a refinish I decided to do it.
Materials used were:
320 and 400 grit wet 3m sandpaper
blue painters tape to mask pistons during prep and painting process
11mm flair nut wrenches for bleed screw and pass through nuts
Air compressor or compressed air cans to clear any fluid left in calipers
I personally wanted to keep cost down so VHT brake caliper paint was the route I went, as opposed to powder coat or professional paint. I used 2 cans for all 4 calipers and bridges
This is a pretty straightforward diy. I opted to use blue painters tape to keep water and sanded off paint off the pistons and seals. After prep sanding with 320 then 400 I would thoroughly wipe down and dry calipers prior to paint. Use new painters tape on pistons to assure no water is trapped under tape.
Remove (2) bleed screws and (1) pass through tube from each caliper. Either stuff pieces of rags or shop paper towels into the (4) holes. OR...buy properly sized bolts from the hardware store to plug holes.
Hang the calipers using the bolt holes for mounting calipers to the car. I went with a light first coat, medium second coat, and finished with a properly heavy wet coat to finish with a nice gloss look.
*I chose to prioritize heavily painting only the area of the caliper which will be visible through the wheel. Why bother wasting paint and risk losing the gloss on the front of the caliper just to coat an area which will never be seen when mounted?
**I chose not to buy the vht caliper clear coat, you may want it
For stoptech logos I initially bought matte black, and went with a 4.5" length, but after applying the stickers I am going to remove those and go with 6" and 5" length gloss black.
More pics will come as I am about ready to pull the car in the garage to remove all 4 wheels and begin install.
      03-04-2018, 05:48 PM   #2
shimmy23
F15 daddymobile
shimmy23's Avatar
2349
Drives: GS X5
Those turned out nice!!! well done man!
      03-07-2018, 02:36 PM   #3
Spun Crankhub
Thanks again!!!
      03-12-2018, 03:56 PM   #4
Spun Crankhub
Larger stoptech logo + gloss
      10-05-2018, 08:15 AM   #5
jjw2331
jjw2331's Avatar
52
Drives: 2011 JtBlk e92 M3
What did you use to plug your brake lines while the calipers were off your car?
Thanks , josh
      10-05-2018, 01:35 PM   #6
Spun Crankhub
Thanks , josh
I took a piece of blue shop paper towel that I ran through the banjo and tied it off.
      01-25-2019, 11:43 AM   #7
cvstar9M3
cvstar9M3's Avatar
Drives: 2011 MR e90ZCP 6-MT
Looks great! Can you please tell me what paint you used? What’s the stoptech paint red paint code? Also where did u get the bigger stickers? Thanks. Going through a similar project now.
      01-25-2019, 11:51 AM   #8
aboutsize14
Drives: 2009 E92
Stop tech uses a two part epoxy paint I believe. Call them up. There in So Cal. The calipers turned out great! Great job. Im in need of this for mine, thanks for sharing.
      01-26-2019, 12:24 AM   #9
Spun Crankhub
Hey thanks!! I recently saw the DDE guy get his Murci's calipers done while on the car, and they looked to turn out okay. Maybe this is the route to go. haha
ItsGary1457.50
m3post
