M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > Headlight washer stuck
      01-06-2018, 04:09 PM   #1
coaxial
Drives: On Order 2017 LBB M2
Hi all - Wondering if anyone has a quick fix.
I have been able to repeatedly engage the headlight washers and the left one gets stuck.
Never gets cold here currently about 64. Generally a simple tap will return it.
      01-06-2018, 04:29 PM   #2
ZM2
Drives: 2017 LBB M2
R2M2.
      01-06-2018, 05:48 PM   #3
coaxial
Originally Posted by ZM2 View Post
R2M2.
Hahaha
      01-09-2018, 04:33 PM   #4
chief1richard
Life is on the Track, the rest is just waiting.
chief1richard's Avatar
Drives: At the point of 7,000 RPM's
2018 M2  [0.00]
I would try a light spray of silicone on piston. BTW how do you activate the headlight washer system? When I pull stalk towards driver it only activates windshield washer.
      01-09-2018, 05:58 PM   #5
coaxial
The manual says it will come on periodically (not really helpful).
I found this works:
-The car needs to be on. Otherwise you keep spraying the windshield. May have something to do with the heather.
-Headlights need to be on (Thank you zm2)
-Then I'll manually engage the windshield washer. On the third pull it seems to come on consistently.
      01-09-2018, 06:31 PM   #6
ZM2
Drives: 2017 LBB M2
I found this works:
I believe the headlights need to be on, as well.
      01-09-2018, 09:14 PM   #7
coaxial
I found this works:
Yes you are correct! Thank you! Modified my post.
m2
