11-04-2017, 11:10 AM | #1 |
Rep 757
Drives: M2
Battery cable nut and bolt p/n
Wondering if anyone knows the part number of the battery cable nut and bolt?
I don’t think it matters as both the positive and negative sides look the same but specifically, I need the negative side. I’ve looked on RealOEM and it only lists the whole cable which is 250 bucks plus shipping. No one will believe me but I stripped this nut taking it off! I was installing the CTEK Comfort Indicator Panel so I just had to remove the nuts on both sides and negative side seemed to get tighter as it was nearing the top (end) of the thread. I had to put the wrench back on to turn it the rest of the way off and now it’s clearly stripped. It did go back on but I’m not happy with it to want to replace it. Thanks!
'17 M2 DCT Long Beach Blue
11-04-2017, 03:20 PM | #3 |
I INDIC8
612
Rep 1,286
Drives: 2018 LBB M2, 6MT
That nut was probably designed to not come off entirely on purpose. You should've snipped the loop from the CTEK lead into a C shape instead of a full ring, then you could've just slid it onto the post without removing the nut.
2004 Matrix XRS 6MT => 2008 VW R32 DSG => 2012 Audi TTRS 6MT => 2018 BMW ///M2 6MT
I'm an IT guy by trade and tech nerd by choice. I like HPDEs, parts of US Hwy 129, NC 28, and the Cherohala Skyway. I'm also a fan of aural pleasure. |
dtmurf481.50 |
11-05-2017, 02:53 AM | #4 |
Rep 757
Drives: M2
Sure, I could see that being the case...the positive side came off and went back on without a hitch. Will stop at the dealer on my way to work tomorrow
11-22-2017, 04:45 PM | #6 |
Rep 757
Drives: M2
Agreed! It's not really a standard nut so I was trying to keep it OEM but they don't sell just the nut and bolt, you have to buy the cable which is 280 Euro...only! I just used an M8 out of my bench stock.
McPurrs290.00 |
