E90Post
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Angel Lights on in daytime 24/7
      10-19-2017, 12:49 PM   #1
ProjectShift
ProjectShift's Avatar
Drives: E92 335 (n54) Deep Green
2010 BMW M3  [0.00]
Car
2008 e92 335 (non idrive)
How can I force my angel eyes to be ON "Full time " without turning on my headlights?
      10-19-2017, 01:14 PM   #2
TheeGovernor
Life is better with burnouts
TheeGovernor's Avatar
97
Originally Posted by ProjectShift View Post
Car
Get them coded.
      10-19-2017, 01:33 PM   #3
floydarogers
Curmudgeon and Pedant
floydarogers's Avatar
Drives: 2010 335d, 2014 328d
Car
It's Key/Car memory; you don't need to code it. Although the dealer usually charges an outrageous fee to do it so it might be cheaper to find someone other than the dealer.
      10-19-2017, 03:34 PM   #4
djh2
Drives: '16 330e
2007 BMW 328i  [0.00]
His car is an '08 so it has to be at least FRM2, which means AE as DRL can be coded. This has been covered in the coding forums of this messageboard.
It's my understanding that LCI, ('09) models can have this selected without coding.
      10-19-2017, 04:04 PM   #5
PTinVT
armchair enthusiast
PTinVT's Avatar
Drives: 18 340xi, 02 325Cic, 93 850Ci
I can do it in my 07 non-idrive through the stalk "key" memory options. Maybe it's a Xenon vs. non-Xenon thing?
'18 340i xDrive EB/Dakota, 6-speed manual, M-sport
'02 325Cic vert AW/Montana leather, 5-speed manual, premium/removable hardtop
'93 850Ci Oxford Green/Parchment, auto
'71 Buick Riviera, 455 V8 land yacht
      10-19-2017, 07:10 PM   #6
djh2
Drives: '16 330e
Isn't that for DRL on off, which are halogen dimmed high beams? In the absence of coding or modifications, I would be surprised. Pre LCI halogen do not have halo rings.
I have an '07 10/06 build with FRM1. I have LED AEs, but it is not possible to code as DRL in FRM1. I have coded AE as DRL and corner delete on a post 3/07 '07 which has FRM2.
      10-20-2017, 08:09 AM   #7
PTinVT
armchair enthusiast
PTinVT's Avatar
I also have a '07 10/06 (US model) but no idea what FRM. I have xenons (single outer headlight that are both low/high beams) and inner halogen "headlights" which are (only) cornering lights; and the AEs are halogen. I can turn the AEs on/off (per key) via my stalk/dashboard display.
      10-20-2017, 10:28 AM   #8
djh2
Drives: '16 330e
You have a coupe though - I think that's the difference that I was not accounting for. My prior comments and experience are on the E90 (sedan). I do know that the E92 has a different headlight assembly than the E90.
In fact, I didn't realize the OP has E92 so all my comments are probably not exactly useful in this case.
      10-20-2017, 11:47 AM   #9
PTinVT
armchair enthusiast
PTinVT's Avatar
I keep forgetting about the coupe/sedan thing as well... but I also have no experience with coding. I hope all of this info is useful to the OP or others who stumble on it in the future Thanks.
      10-20-2017, 12:12 PM   #10
lukasB
God
lukasB's Avatar
97
Drives: 09 E92 N54
1. Push the turn indicator stalk up or down repeatedly until the symbol appears in the display accompanied by the word "SET"
2. Press BC button
3. Push the turn indicator stalk down repeatedly until the "sun" symbol appears in the display
4. Press BC button
5. Use stalk to select "ON"
6. Press BC button
      10-20-2017, 02:26 PM   #11
PTinVT
armchair enthusiast
PTinVT's Avatar
2. Press BC button
4. Press BC button
6. Press BC button
Thank you. Note, there may be 2 SET options, one with a "key" icon and one with a "ruler" icon - the "sun" symbol will be under the SET/"key" menu.
lukasB97.00
e90post
