Stripped oil plug/pan? Question about threads
10-17-2017, 11:50 AM | #1 |
Rep 388
Hi all,
Posted this in the tech section, but thought I'd try here as well. I am the owner of a 2006 330i. I went to do a routine oil change and found that the oil plug just keeps turning and turning. From looking at this forum, it seems this is not an uncommon occurrence. The problem I'm having is what the mechanic at a local import shop is telling me. He is telling me that the pan itself is not threaded and that there is a "bolt" inside the pan that the plug threads into, and this is what broke away causing the plug to keep turning. I was under the impression that the pan was threaded and the plug simply threads into this. Can someone confirm or deny what the mechanic is telling me is accurate? If it's just the threads on the plug, I have a new plug to replace it. If it's the threads on the pan, I was told that this can potentially be repaired with a heli-coil insert. I'm just trying to avoid a $1,200 bill if possible. Thanks in advance. |
10-17-2017, 12:22 PM | #4 |
Rep 388
Thanks for the replies. I feel like the mechanic doesn't know what he's talking about. As I recall, there are threads right on the pan itself, though he's saying that's not the case. I didn't think there was a "bolt" inside the pan that the plug threads in to. I think I'm going to take it elsewhere.
Thanks again. |
10-17-2017, 12:41 PM | #5 | |||
Rep 52
Both the options above are easy to do and should be permanent though.
10-17-2017, 01:04 PM | #6 |
Rep 952
This is a very common problem and kits are made to repair the threads. Someone mentioned heilicoil. My personal experience is using timesert and they work very well.
http://www.timesert.com/html/drainplug.html
bone stock
10-17-2017, 02:27 PM | #7 | |
Rep 388
10-17-2017, 03:08 PM | #8 |
Rep 7,215
the pan is definitely threaded. There's no "bolt". Somebody (your mechanic?) probably cross threaded it at some point or way over tightened it.
FWIW the RWD/manual cars use a steel pan; auto/xi cars are aluminum. It's not that easy to strip the threads on the aluminum pan, much less steel. |
10-17-2017, 03:31 PM | #9 |
Rep 1,016
Are mechanics just stupid or dishonest. I don't know anymore.
But I bet if I had the same problem I wouldn't be able to find a mechanic to rethread my pan either. They prob would refuse to do it stating they can't warranty that type of work. |
10-17-2017, 03:41 PM | #10 | |
Rep 388
I am definitely taking it somewhere else. When my wife went to pay the bill and get my key, the guy tried charging me for a windshield washer fluid fill (which I just did myself a few weeks ago and haven't used the washer fluid since), and an oil filter (why would you put in a filter if you can't get the plug out to drain the oil?!). Mind you, I did not authorize them to do anything to the car once he told me that the "bolt" inside the oil pan broke off. Luckily my wife called me and we were able to have those charges removed. They then told my wife that we are no longer welcome at their garage (as if I'd go back there anyway). First and last time I deal with those guys. C&W Imports in Lancaster, PA for anyone here that would consider going to them. |
10-17-2017, 04:05 PM | #11 | |
Rep 1,016
You should one star them on yelp.. They look like a fairly new garage with only 4 reviews. Prob all them and their family. |
10-17-2017, 04:22 PM | #12 |
Rep 211
It’s anyones guess if it’s the bolt or the pan. If I had to guess, probably the pan but if it were me, I’d replace the bolt and repair/chase the pan threads.
Two other things, if it spins in the drain hole that also means it’s going to leak. Fix quickly and watch your oil level. When you fix it, make sure you pour a couple quarts of oil through the fill hole and out the drain before you put the bolt back in and fill it for good. Yes, you will waste the oil but you need to get the shavings out from cutting new threads. The “right” way would be to pull the pan off but I get that it’s a huge PITA to do this. |
10-17-2017, 04:28 PM | #13 | |
Rep 388
They actually tried charging me $30.00 over the price they quoted me 2 hours prior to my wife going to pay the bill. |
10-18-2017, 06:12 PM | #14 |
Rep 199
Before tapping new inserts I would find a mechanic that can chase and clean up the threads to see if it's salvageable that way (and use a new bolt). My drain bolt wasnt spinning in it's slot like yours but some of the threads felt tight so I cleaned it up with a harbor freight tap and die kit and it's been fine ever since.
10-18-2017, 08:55 PM | #15 |
Rep 18,740
I gave you a good answer in your thread (no pun intended) in the tech Forum.
