PSA: E90 Front Tire Width Limitations
10-16-2017, 10:28 AM | #1 |
Rep 3,336
Drives: X5 & E90 WTCC Widebody Racecar
As more and more of us turn our e90's into dedicated race cars, I wanted to document this issue as its an issue that turb0mik3, soursamo and I have encountered as we throw much wider meat up front on our e90's.
Beyond the typical fender rubbing issues associated with wider wheels which can be remedied with a wide body kit... there is a body/firewall limitation up front if you're wanting to run a 265 or wider wheel package. A 265 or wider tire up front requires either a lower offset wheel or a spacer to push the wheel away from the suspension (rubbing). This push outward increases the radius of the outer part of the wheel, beyond OE spec and causes it to rub parts of the firewall when wheels are turned. That said, here's a quick reference guide I put together from what we've discovered. This is only for the e90 chassis (sorry can't comment on e92's) and it doesn't take into account width variances between tire manufacturer. This also assumes proper wheel offsets. E90 Front Tire Widths: 245 or under: No modifications needed 255: Possible fender roll (depending on suspension setup/drop) 265 - 285: Widebody/cut fenders + cut out firewall seam weld 295+: Widebody + extensive modification to firewall Passenger side front wheel well. Notice the seam weld behind the tire: Highlighted the rub area in red. Fortunately this part can be removed fairly easily: Last edited by sirdaft1; 10-16-2017 at 10:53 AM.. |
10-16-2017, 10:53 AM | #2 |
Rep 803
Good thread.
There is also a small hump in the inner rear section of the front wheel well that can rub too. Thankfully nothing in that area is highly critical so it can take the brunt of a big fucking hammer :P |
10-16-2017, 10:58 AM | #3 |
Rep 3,336
10-16-2017, 11:08 AM | #4 | |
Rep 803
10-16-2017, 04:41 PM | #5 |
Rep 1,869
For what it's worth. I just put on a 255/35/18 MPSS on a 18x9 et31 wheel. I have an 09 e90. Im sitting on KW V2s, almost max height. It cleared all fenders and such, I'm rolled, and running only 1.2 camber that's all. However the MPSS is a fatty of a tire so over large dips I would rub hard.
I can easily run any other summer/all season 255 tire with zero issues. So basically a 255 MPSS is sized more relative to a 265. So a 265 and up would fit imo with certain tire brands and a little bit of camber. The 255 mpss was pretty much flush if anything it poked a tiny bit. Hope this helps anyone
07 335xi (2007-2010)
08 Legacy Spec B (08-) 09 335i (2010-) 15 X5 xdrive 35i (2015-) 17 Forester XT (2016-) |
10-16-2017, 05:10 PM | #7 | ||
Rep 3,336
Now that I have a 275 width up front, firewall clearance is EXTREMELY tight (as the photos above show). soursamo is running a 265 front and mentioned that he had to cut out the seam weld and pound in the firewall hump to avoid rubbing. If anything, this was something I had never heard mentioned before. It’s something to be aware of and worth double checking fitment for anyone planning to run an aggressive wide front tire. |
10-16-2017, 05:17 PM | #8 |
Rep 803
I think the internal rubbing really boils down to wheel width; I could clear a lot of those bumps if the wheels were narrower and higher offset, but then you can't run as big a tire.
10-16-2017, 11:19 PM | #9 |
Rep 655
this is great info as i go towards a squared setup, and trying to get as much meat as i can
2011 lci with rolled and pulled fenders, thinking about coil overs with camber plates, hotchiss end links, eibach sway and possibly bigger brakes |
