E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Vibration under braking, likely control arms, reccommendations
      10-13-2017, 07:37 PM   #1
messyhead86
Drives: 335d M Sport
I've got a lot of vibrations on the my e91 under braking. The discs have been changed so the only other likely culprit is the control arms or wishbones from what I've read.
I've read that the m3 wishbones and control arms give a better feel and last longer. Has anyone got any recommendations of model numbers so I can look to order some. I've seen a lot of posts but no model numbers.
Cheers
      10-13-2017, 07:39 PM   #2
rick100
Drives: 328
M3 control arms wont work on awd models .sorry i cant see what u have on phone
      10-14-2017, 12:14 PM   #3
BravoJohny33
Drives: BMW 2010
Just go standard oem from tischer.
      10-23-2017, 03:01 AM   #4
Austin LeNomad
Drives: 2006 E90
Do upper and lower control arms
While you are at it, check your tie rods, and replace them while under there, with the control arms removed, it makes it very easy to do with all the clearance. My first tie rod had siezed by 80,000 miles and the second by 95,000 miles. I had to cut them off they were in such bad shape.
      10-23-2017, 03:03 AM   #5
Austin LeNomad
Drives: 2006 E90
I ordered stock replacement ones from RockAuto
I got mine from RockAuto, they had the oem replacement ones. When done, go straight to get an alignment done.
e90post
