E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Footwell panel removal
      10-11-2017, 06:46 PM   #1
RED-d
Drives: 2010 335d Sport, Tuned
I've got the screws from the top and side panels out, but can't figure out how to remove these panels so I can get to my FRM module.
Are there clips somewhere?
      10-11-2017, 08:35 PM   #2
PichaDis11
PichaDis11's Avatar
Drives: E90 N52
Pull the panel a little bit towards the drivers seat. It is held in place by the 'hook style plastic' (if you may) to the right and also atop the foot rest. It'll drop down a little after that. Disconnect wires for the footwell lighting MOST port connector and loud speaker if present.
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit
      10-11-2017, 09:33 PM   #3
RED-d
Well, I just found out I'm a pessimist. I lost count how many times I said "I can't get this, or that".
Thanks PichaDis11. That was the info I needed. I was never able to disconnect the light cable of all things, so needed to work with the upper panel dangling in my way.
Fortunately, I read somewhere to just loosen the upper plastic bolt. If I'd have taken that out it would have stayed out. Btw, someone else said that their plastic bolts were phillips head. Mine were 10mm.
Now that I know my true colors, I can proudly say, "I don't know how I'm going to get all that back together".
e90post
