Need MULF 2 box and all cables
10-04-2017, 06:50 PM | #1 |
V8 Bait
206
Rep 769
Right now, i have ZERO music streaming ability in my 2010 E92 335i. Theres a very stupid reason for it, too. Either way, i need some parts:
-mulf 2 box in the trunk is missing, its the one that should go on that empty bracket -all corresponding cables for mulf 2 box -USB/AUX input box and its cables I can possibly get the mulf 2 from a seller on this site. I can always just order the AUX/USB box and its cable too. I have no idea what the mulf 2 cable looks like or where to get it. If there is anyone who knows what else i need, please speak up, especially those who have messed around with this stuff. I really could use the help. |
10-04-2017, 07:33 PM | #2 |
Rep 2,202
Does You car have nav? Get a combox Unit.
If not - You'll need this plug part # 61136920074 - Then a USB Cable 61119129360. Go to the Connected Drive Section and look up Bluetooth Retrofit for more info. This has been beaten to death and back over there.
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit |
10-04-2017, 07:39 PM | #3 |
Rep 13,103
Whats the box in the picture because the empty slot on the other side
is for the Sat module. Close ups of the labeling please. Only a combox will do streaming and you must have idrive for streaming to work. You can do usb with a mulf 2 hi but no A2DP. |
10-04-2017, 07:42 PM | #4 |
V8 Bait
206
Rep 769
Sat module? i have XM radio and nav, but no box. Anyways, thanks.
Im also not interested in combox. I simply want to hook up my aux cable and listen to music on my phone the old fashion way. That first part # gives this: https://www.ecstuning.com/b-genuine-...r/61136920074/ Where would that even go? Last edited by The_E92_Fan; 10-04-2017 at 07:48 PM.. |
10-04-2017, 08:07 PM | #5 |
Enthusiast
167
Rep 1,622
Box in the pic is Bluetooth tcu, he has cic so his xm is built into the head unit
10-04-2017, 08:22 PM | #6 | |
Rep 2,202
This is the connector housing that fits the MulfII Unit. Basically take the two connectors of the white plug from your tau and pin them accordingly and place it to the new plug connector. You have to run new cables for AUX to work again as well.
10-04-2017, 09:40 PM | #7 |
Rep 13,103
Yes you can get aux and usb with a mulf 2 high but you
might as well get a combox to get streaming. (because you said streaming ) Either one will give you usb and aux but only the combox will give you aux , usb and wireless streaming. |
10-04-2017, 09:43 PM | #8 |
Rep 13,103
might as well get a combox to get streaming. (because you said streaming ) Either one will give you usb and aux but only the combox will give you aux , usb and wireless streaming. You should also be prepared for the programming you are going to need to do to integrate this module with your car and idrive. |
10-05-2017, 08:04 AM | #9 | |
V8 Bait
206
Rep 769
