Have you seen this crack before ?
09-30-2017, 12:46 PM | #1 |
Rep 54
Hi guys,
Having misfire cylinder 4 so I said ok let's try replacing all plugs and coils. Didn't get to touch them and I see oil, not good... looking a bit more the plastic housing is cracked, not sure how that really happened, I own the car for less than 10,000 KMs and I bought it with 80,000KM. I am guessing a bad mechanic probably was trying to do work on the injector and somehow cracked it or I don't know.. Anyways, not sure how long this is like that for.... I am planning to get the coils and plugs replaced either way and now looking to buy that part new or used. Have you seen engine valve covers cracked like this ? Thank you |
09-30-2017, 01:13 PM | #2 |
Is it the shoes!?
3884
Rep 5,112
Not like this specifically, but I have seen them crack before. It's really unfortunate, and is a good example of why plastic valve covers are no fun. You could probably do a temporary repair with JB weld or similar, but I'd get a new cover soon.
09-30-2017, 01:42 PM | #5 |
Rep 3,557
I've had JB weld hold on a higher pressure situation. It was a pin hole on a metal thermostat housing. Different make. Worth a try but it will look ghetto. You will need to sand/prep surface and get oil off area to get it to stick. There is little pressure so it should work. Actually, my M57 diesel is under slight vacuum in this area due to breather feeding into the turbo inlet. Not sure what engine you have in these pics as I'm not familiar with N52,N54 nor N55 engines. Good luck.
09-30-2017, 10:48 PM | #8 |
Rep 54
will try JB Weld and other solutions first...just for a crack like this I dont feel like working 4 hours plus hundreds on that plastic cover which in the end will crack again I am guessing.
