E90Post
Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > BMW 335i e92 2010 || Error Codes 36c9 - Engine malfunction reduced power
      09-28-2017, 02:30 PM   #1
wynes
wynes's Avatar
10
Drives: BMW 335i
Hi there,
I’m new to this site so I’m hope I’m posting this in the correct place - I’m sure I’ll be corrected and pointed in the right direction if it’s not.
I was driving the other day and accelerating reasonably hard in 3rd gear and around 5000rpm (I think) I received the “engine malfunction reduced power” error come up on the dash and CIC. I have had a similar issue in the past, but this time the engine really went into limp mode and was barely enough power to keep the car from stalling.
Anyway, same old story, turned the car off, let it rest for a minute or so and everything returned to normal.
Here’s a list of my error codes from Carly, hope someone can point me in the right direction as I’m pretty new to e92’s
This seem to be the main issue,
Motor Control:
Engine / Motor
Internal Error DME
Code: 0036C9 / 36c9
I’m pretty sure this one turned up at the same time,
ABS / DSC / Brake:
Dynamische Stabilitaets Kontrolle / DSC
Engine torque is not adjustable CAN
Code: 005E19
This is the freeze frame Data,
Faultcode: Internal Error DME
Faultset 1:
(appeared at: 99320.0km)
speed monitoring:
0.00 1/min
Engine torque actual monitoring:
478.00 Nm
Engine torque setpoint monitoring:
28.00 Nm
inserted syringe fuel mass:
98.00 l/h
Faultset 2:
(appeared at: 262144.0km)
speed monitoring:
0.00 1/min
254.00 Nm
96.00 Nm
39.00 l/h
Faultset 3:
(appeared at: 784.0km)
speed monitoring:
560.00 1/min
0.00 Nm
256.00 Nm
239.00 l/h
Faultset 4:
(appeared at: 312.0km)
speed monitoring:
1920.00 1/min
196.00 Nm
0.00 Nm
127.00 l/h
Faultset 5:
(appeared at: 30584.0km)
speed monitoring:
5120.00 1/min
78.00 Nm
0.00 Nm
0.00 l/h
Any help would be much appreciated, many thanks in advance!!
Cheers!
      02-15-2018, 04:32 PM   #2
Don2012
Drives: 2011 BMW 335XI N55
Unhappy Figured it out yet ?
Originally Posted by wynes View Post
Hi there,
Motor Control:
Engine / Motor
Internal Error DME
Code: 0036C9 / 36c9
ABS / DSC / Brake:
Code: 005E19
Faultset 1:
speed monitoring:
0.00 1/min
478.00 Nm
28.00 Nm
98.00 l/h
Faultset 2:
speed monitoring:
0.00 1/min
254.00 Nm
96.00 Nm
39.00 l/h
Faultset 3:
speed monitoring:
560.00 1/min
0.00 Nm
256.00 Nm
239.00 l/h
Faultset 4:
speed monitoring:
1920.00 1/min
196.00 Nm
0.00 Nm
127.00 l/h
Faultset 5:
speed monitoring:
5120.00 1/min
78.00 Nm
0.00 Nm
0.00 l/h
Cheers!
Did you figure it out yet ? Mine does the same thing when it’s in limp mode my DSC 4X4 Yellow brake all these lights pop up and pulled codes are
002C58 Charge Lock Down
0036C9 Internal Dme error ?!
0055C3 can’t find any info about this one
My oil filter housing gasket needs replacement but that’s not a link to this issue
I was getting Over boost codes with halfchecknlast week randomly and it would run with no boost till restart.
      02-26-2018, 03:16 PM   #3
turbooo
Drives: E92 2013 335i
2013 335i  [0.00]
Do you have any mods on the car? I've had this happen to me three times. Each time it happened I was able to pull over, restart the car and drove fine after.
I believe this was happening because I was missing the bung hole screws on my VRSF chargepipe and had a huge boost leak. I've put about 2000 miles on it since and the issue hasn't come back.
      02-27-2018, 02:14 PM   #4
mohamedn44
Drives: 335I-E92
That right, its just a leak in your charge pipe thats all it can be a pipe going bad or some type of leakage
      02-27-2018, 02:30 PM   #5
BMW ONLY
Drives: N51 E92 328iC 2009
Hi there,
IÂ’m new to this site so IÂ’m hope IÂ’m posting this in the correct place - IÂ’m sure IÂ’ll be corrected and pointed in the right direction if itÂ’s not.
HereÂ’s a list of my error codes from Carly, hope someone can point me in the right direction as IÂ’m pretty new to e92Â’s
Motor Control:
Engine / Motor
Internal Error DME
Code: 0036C9 / 36c9
IÂ’m pretty sure this one turned up at the same time,
ABS / DSC / Brake:
Code: 005E19
Faultset 1:
speed monitoring:
0.00 1/min
478.00 Nm
28.00 Nm
98.00 l/h
Faultset 2:
speed monitoring:
0.00 1/min
254.00 Nm
96.00 Nm
39.00 l/h
Faultset 3:
speed monitoring:
560.00 1/min
0.00 Nm
256.00 Nm
239.00 l/h
Faultset 4:
speed monitoring:
1920.00 1/min
196.00 Nm
0.00 Nm
127.00 l/h
Faultset 5:
speed monitoring:
5120.00 1/min
78.00 Nm
0.00 Nm
0.00 l/h
Cheers!
I had the limp mode a couple of years ago. I didn't check for codes. I only changed my spark plugs and cleaned the eccentric shaft sensor.
      08-25-2018, 05:25 AM   #6
wynes
wynes's Avatar
10
Drives: BMW 335i
BMW recommend replacing the ECU so they did, luckily under a 3rd party mechanical warranty (cost 2.5k NZD). Unfortunately, this didn't fix the fault.
Im now going to replace the High Pressure Fuel Pressure Sensor.
Also, i run 91 octane, i am cosidering changing to 95 or 98 octane.
Fault Code: 0036C9
Fault Explanation: DME, internal fault, safety function: plausibility
relative fuel mass
      08-25-2018, 05:29 AM   #7
wynes
wynes's Avatar
10
Drives: BMW 335i
Rear muffler delete, KN air fulter, no other mods.
Always happens to me at 4000rpm 3rd gear full throttle, i have to change just before 4000rpm and everythings fine, hasnt happened in any other scernario.
When it happens, like you, i pull over and restart the car.. and its all good.
      02-20-2019, 07:20 PM   #8
wynes
wynes's Avatar
10
Drives: BMW 335i
Replacing High Pressure Fuel Pressure Sensor resolved this issue
      02-24-2019, 09:29 AM   #9
335ivin
Drives: 335i Sedan
Glad to hear you fixed it. Cheers brother
      07-02-2020, 12:51 AM   #10
neo61uk
neo61uk's Avatar
Drives: F31 340i Performance Edition
Fault Code: 0036C9
relative fuel mass
Hi Wynes
Sorry for digging out the old thrd but currently just started having same issues.
2012 335i n55
Jb4 catless downpipe intake
Running like this 2 years no issues.
Two days ago overtaking on 75% throttle and boom
Limp mode and two same codes as yours.
36C9
5E19
Do you remember if any of those codes disappeared after bmw replaced DME unit?
Or both of them were still present?
I'm surprised they didn't change the sensor first to try.
Did you change the sensor yourself or they did it under warranty after dme?
Buying the sensor now to replace but trying to figure out if it was only sensor in yours or both.
Also some people suggest it can be boost leak. But I assume if its a leak it would go into limp mode every WOT, and in my case Im having issues to replicate it. Happened twice already but random, trying to drive it like i stole it and it drives perfect for two days, then suddenly goes to limp mode.
Any help appreciated.
Regards
Martin
      07-08-2020, 03:06 PM   #11
neo61uk
neo61uk's Avatar
Originally Posted by neo61uk View Post
Hi Wynes
2012 335i n55
36C9
5E19
Regards
Martin
Replying to my own question here.
If you have those two codes together its the High Pressure Fuel Sensor on fuel Rail.
£68 from BMW (Bosch)
30 min work
Problem solved.
Tags
335i, code 0036c9, engine malfunction reduced power, n55
e90post
