E90Post
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Are any companies working on an OFHG solution?
      09-24-2017, 03:53 PM   #1
Welcome to NBA Jam
Is it the shoes!?
Welcome to NBA Jam's Avatar
3884
Drives: (Sold) 2011 E92 335i ZMP 6MT
We all know that the OFHG isn't very good on these cars. They flatten and plasticize after only 60,000 miles. Is anyone working on a more robust seal, like Viton, for the N54/N55? Is there any interest in it?
      09-24-2017, 05:01 PM   #2
ctuna
Drives: 325xi 06 wagon MT
I thought I had read that someone was making a gasket
out of some different material that was suppose to last
longer .
https://blog.bavauto.com/13429/bmw-o...0-m52-m54-etc/
      09-24-2017, 05:43 PM   #3
BimmerNugget
Crazy Frog
BimmerNugget's Avatar
Drives: L.L.Bean Bootmobile
No, no one is going to create a solution to a $5-$10 problem. That damn gasket is literally $6 and maybe 2 hours to DIY. My N51 just recently start leaking a little bit and I plan on DIYing it very soon.
Even if you don't DIY, this is a $200 job (parts & labor) at an independent shop.
I don't even know why people make OFHG such a big issue on the E90s. Valve cover gaksets, Oil pan gaskets, water pumps/thermostats, and starter motors are the bigger issues.
tlow982188.00
      09-24-2017, 09:37 PM   #4
TemjinX2
Drives: 2008 335xi e92
i would like a better gasket, but too be honest it would probably difficult to get the kind of volume you need to make it cost effective in terms of R & D and manufacturing.
I still dont get why a japanese gasket lasts 160k and a german one only lasts 60k.
      09-24-2017, 10:32 PM   #5
Captain comic
Captain comic's Avatar
157
Drives: 2008 328xi
Because Greenpeace is strong in Germany and materials are biodegradable. BMW made a big deal about it. Same with efficient dynamics and mass hysteria with electric cars i3/i8 etc.
Japanese - they don't care about ecology (look at Fukusima nuclear plant - still leaking contaminated waste int ocean), but they do care about longevity of their cars and parts
      09-24-2017, 10:47 PM   #6
TemjinX2
i dont really get that way of thinking? why would you need a engine gasket to biodegrade? Wouldnt that create more waste since you have to throw away the old one and buy another one?
      09-24-2017, 11:18 PM   #7
Efthreeoh
Drives: The E90 + Z4 Coupe & Z3 R'ster
Why don't you go ahead and just make some shit up...
LOL
Greyfox1207.50
Meeni329.00
alpnwss31.50
      09-24-2017, 11:54 PM   #8
The Nightman
Cometh
The Nightman's Avatar
1090
Drives: Boy's Soul
I wonder if the newest revision (#11428637821) is better? It was updated in April 2015 and is used on the F series models:
http://www.realoem.com/bmw/enUS/part...&q=11428637821
I replaced mine with it and noticed it has more ridges than the previous gaskets:
      09-25-2017, 12:11 AM   #9
ctuna
Most engines that I have had are designed such that the
Filter screws directly into the Engine Block needing no
Filter Housing at all.
What I don't understand is this has apparently been a problem long before even the e90 series . So why hasn't there been a design change.
      09-25-2017, 07:52 AM   #10
robthewrench
Drives: 11 E90 335i
Two things to point out:
- The design is the problem, not the gasket material.
- The reason it doesn't last is because of heat. BMW designs most of their recent engines to run hotter than prior decades. This makes it easier to get the most power from the fuel and reduces emissions by fully burning more molecules of the fuel (less un-burnt goes out the exhaust).This is also why BMW requires a really good synthetic oil to perform under this heat (while some other cars / trucks can still use conventional or syn blend oil). However, heat is the enemy of gaskets. More heat = more brittle gaskets = more leaks.
bone stock
      09-25-2017, 08:36 AM   #11
delmarco
delmarco's Avatar
Drives: 2011 335xi Deep Sea Blue
Glad they don't make car tires out of the same rubber then...
I purchased an aftermarket OFHG from ECStuning that is rumored to last longer than the OEM replacement. It was cheaper as well.
IDK.
Just like the shoemaker don't care about the laces on they shoes they sell I doubt BMW will care about the $2 gaskets in a car they are selling for $40,000 to $60,000!
VISIT MY GARAGE TO SEE MY BMW E90 MODS:
http://directory.e46fanatics.com/use...Mod&UcId=20832
      09-25-2017, 04:24 PM   #12
TemjinX2
i hope your right...i just replaced mined with the newer part number.
      09-25-2017, 04:51 PM   #13
BashShah
Drives: 2012 335i Sedan
I have a solution.
and it went through a lot of R and D.
it's Called: Permatex Ultra Coper
you put a small amount around your NEW Gasket....
NO MORE LEAKS.....most likely EVER.
follow instructions on product.
Donutz139.50
      09-26-2017, 09:00 AM   #14
delmarco
delmarco's Avatar
Talking
Originally Posted by DarkNemesis View Post
I have a solution.
Yeah because that is like Krazy Glue made from material off the surface of planet Mercury!
That stuff is permanent man...
      09-26-2017, 11:07 AM   #15
The Nightman
Cometh
1090
Drives: Boy's Soul
IDK.
Any more info on this?
      09-26-2017, 11:32 AM   #16
delmarco
delmarco's Avatar
https://www.ecstuning.com/b-genuine-...428637821~oeb/
      09-26-2017, 11:40 AM   #17
BashShah
Not permanent.
It's like rubber, come off, very easily.
The result is like rubber.
But can withstand high temps and oil.
      09-26-2017, 12:17 PM   #18
Captain comic
157
Drives: 2008 328xi
LOL
For you my slow thinking friend opening a geography atlas may blow your mind. It's called science. Not everything is woodoo
      09-26-2017, 01:16 PM   #19
lukasB
God
lukasB's Avatar
97
Drives: 09 E92 N54
BMW gaskets are made out of ACM (acrylic rubber). Material temperature range is 14*F - 302*F it's water and moisture resistance is poor, as is resistance to acids and alkalis. It has a good resistance to heat, oxidation and hydraulic oils and is cheap
JonOhh672.00
      09-26-2017, 03:12 PM   #20
Wolf 335
Wolf 335's Avatar
Drives: 2007 E92 335i
Not permanent.
So what did you do, can you walk us through your steps?
You placed the gasket in the groove and then applied permatex on top of the gasket?
      09-26-2017, 03:44 PM   #21
delmarco
delmarco's Avatar
NO from what I googled this gel paste REPLACES the actual gasket. So you squirt it in the place the gasket goes and it dries becoming a gasket in itself!
Almost as if you are gluing the halves of the filter housing together at the seam that the gasket sits in.
      09-26-2017, 05:51 PM   #22
Sgop335
Sgop335's Avatar
Drives: 07 335i e92, 08 535i
Perhaps so, but i think DN is using in addition to the gasket. Would be interested to hear what he did.
335i e92 TPC 19Ts
e90post
