E90Post
Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Adjust waste gates with inlets installed?
      09-21-2017, 01:18 PM   #1
The_E92_Fan
V8 Bait
The_E92_Fan's Avatar
206
Drives: your mom
The usual way of adjusting the rear waste gate is to go in from the top, but with MMP inlets installed, thats not an option. Is there any easy way to go from below? I really don't want to take off the rear inlet since its such a PITA to get back on. Remove DP?
I want to see pictures of the washer method of adjusting the waste gates. I don't understand where these 2 bolts are at that must be removed, as from what i can tell, the waste gates have 3 bolts on the back of them. Any thread i look at that may have these pictures on them, the picture isn't working. An what is this C-clip people are referencing? i don't have that, and again, no picture shows where its at.
      09-21-2017, 03:41 PM   #2
CoffeeBean
Drives: 640i M-Sport GC
The rear turbo actuator can be accessed from underneath. You may have to move the steering rack (2 bolts), I can't remember.
These 2 threads have the best info:
http://www.e90post.com/forums/showthread.php?t=1412827
http://www.e90post.com/forums/showthread.php?t=890145
Here are the 2 bolts on the actuator. You're not touching anything on the other side of the arm where it connects to the WG, including the C-clip.
      09-21-2017, 05:48 PM   #3
The_E92_Fan
V8 Bait
206
Drives: your mom
So one just backs off those bolts enough to fit 2 washers (modified to make a C)between each bolt head and bracket face then tightens the snot out of them?
      09-21-2017, 05:56 PM   #4
The_E92_Fan
V8 Bait
206
Drives: your mom
I think ill make a video describing what i do. when I'm done, ill make sure the video becomes a sticky on the forum main. You helped me, ill help the masses.
      09-22-2017, 12:19 AM   #5
CoffeeBean
Yeah I actually took the top bolt out and used whole washers, but the bottom is harder to get to so I loosened it and slid in cut washers. The washers go between the bracket and the compressor housing though. Wouldn't do anything the way you described it.
      09-22-2017, 08:50 AM   #6
The_E92_Fan
V8 Bait
206
Drives: your mom
Thanks for clearing things up. Ill be doing this next weekend and upload a detailed video
e90post
