Driver Door Actuator Question
09-21-2017, 10:46 AM | #1 |
Rep 41
I just had an issue with my doors not opening which was easily fixed by replacing fuse 57. Now, a couple days later my driver door is the only one not responding.
I checked fuse 56 & 57 again and they were good. It seems like quite a coincidence that this started at the same time. Is there anything else (fuses) I should check before taking it to the dealer for service of the actuator? |
09-21-2017, 10:50 AM | #2 |
Rep 1,203
If the fuse blew, You need new door lock actuators (Both front doors) ..only a side note if the fuse is blown your suppose to replace it with a 20amp fuse as well.
09-21-2017, 11:23 AM | #3 |
Rep 41
Thanks. I have replaced door fuses before without any issues with the actuator but I do think it's shot. Fuse 57 does have a 20a but 56 is a 15a. I see on the fuse layout card that there are several other fuses associated with the driver door (2, 19, 63) that I haven't checked yet.
09-21-2017, 11:56 AM | #4 | |
Rep 1,203
Inspect fuse 57 (up to 9/07 production) or 73 (from 9/07 production) in the JBE. Replace the blown 15A fuse with a 20A fuse. |
09-21-2017, 01:21 PM | #5 | |
Rep 6,968
Drives: 2007 Black/Black 335i e90
There is one on this forum I believe or you could google it. |
