08-19-2017, 08:37 AM | #1 |
Rep 38
can't start the engine after flashing
Hi Guys,
Unfortunately i have a big problem after flashing almost all ECU's with Esys. First of all i was not able to flash because of a TAL error (Fatal error while executing tal! - FA must be set....(1358). So i flashed without cddeploy because i friend said so. After flashing EGS and FLA no problem with anything but the i flashed all other ECU's (not ACSM) and now i can't start the engine and a lot of failure messages appears like: driving stabilisation, increased stee. effort., fuel supply, convertible roof - check secure (even if i don't have a convertible roof), parking break failure, lane departure warning failure (don't have it), drivetrain fault, Park assist (don't have it), front end collision warning failure (don't have it), traffic jam assist failure (don't have it), driver assistance (don't have it), SOS call system failure (don't have it) and finally instrument cluster update required. My car is an european 318d touring (F31) I tried already to delete all Errors with Tool32, but a second later all of them appear again. Can someone help me? Thank you very much in advance. |
08-19-2017, 07:40 PM | #3 |
Rep 38
THX but i fixed it now by coding all the ECU's again with cddeploy. Problem was that first you have to hit Read VIN out of FA and then Read FA, but in all instructions it is mentioned in the other way around.
08-23-2017, 12:22 PM | #6 | |
Rep 8,364
Here are some: Fxx-/Ixx-/Gxx-series Coding: Getting Started Guides, Tips, & Cheat Sheets |
08-23-2017, 12:31 PM | #7 | |
Rep 477
08-23-2017, 12:43 PM | #8 |
Rep 8,364
CAFD, VO, CAF - Coding Terms. Defined in previously linked OP.
ISTA+ - Diagnostics & Programming Software. (Guide) Software Overview ACSM, FLA, EGS, FEM - ECU (Electronic Control Unit) Modules. These are defined in Training Docs. ACSM = Advanced Crash Safety Module. TAL - Programming term. Transaction List. These are also found in E-sys VCM User Manual. Abbreviation / Significance
08-23-2017, 12:50 PM | #9 | |
Rep 477
Thanks for that. Question: Is it possible to code doors to unlock when transmission is put in park? I didn't see it on any of the programming lists I've seen for Bimmercode. |
08-23-2017, 12:51 PM | #10 | |
Rep 8,364
There is coding for auto-unlocking when engine is turned off. I have not seen any for when in Park. But, if you press start/stop, engine is turned off and vehicle goes into P. |
