BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
EXXEL Distributions
      05-12-2008, 04:48 PM   #1
rvacha
rvacha's Avatar
Drives: '08 E92 M3
2008 E92 M3  [0.00]
Let's Analyze The Break-in Oil, Shall We?
The most interesting thing about this report is, well, there's nothing very interesting to report. Oil tested to be nominally 20W-50. Perhaps this will serve as a nice baseline or data point for somebody someday.
You may now resume whatever it was you were doing
'16 F30 340i xDrive 6MT Melbourne/Black
'08 E92 M3 6MT Jerez/Speed Cloth
'18 F80 M3 6MT SO/CSAT
      05-12-2008, 05:05 PM   #2
WCH
WCH's Avatar
Drives: '20 M8C convertible
Thanks for the info. Have you had this done with your other cars?
      05-12-2008, 05:37 PM   #3
rvacha
rvacha's Avatar
Drives: '08 E92 M3
2008 E92 M3  [0.00]
No, I haven't. But I was curious as to whether the break-in oil was different and whether the break-in period resulted in a lot of engine wear. It'll be interesting to see how much these numbers fall after another oil change or two
      05-12-2008, 05:43 PM   #4
rvacha
rvacha's Avatar
Drives: '08 E92 M3
2008 E92 M3  [0.00]
FYI, I don't know if this qualifies but by total freak coincidence the odometer hit exactly 1200 miles when I rolled into the dealer. The key, however, said 1201, so I guess I can't chalk that up in my book of Cool Things That Will Never Happen Again. The dealer said this discrepancy "happens" and suspects that the key stores the actual miles (as best as can be determined) as opposed to the miles reported by the odometer (which runs deliberately high, just like the speedo)
      05-12-2008, 05:59 PM   #5
asaulo1
asaulo1's Avatar
38
Drives: 2008 M3 Coupe, alp white
so, is it or isn't it true that they use a different type of oil (break in) in our cars for the 1st 1200 miles?
      05-12-2008, 06:11 PM   #6
rvacha
rvacha's Avatar
Drives: '08 E92 M3
2008 E92 M3  [0.00]
Hard telling.... I don't know if there is a enough variability in the tests such that a 10W-60 oil could test 20W-50. If the tests are accurate then the answer would seem to be no.
      05-12-2008, 06:12 PM   #7
epiphone3
Drives: 2013 BMW X3 35i
Looks like it definately is true since the nominal weight of the oil in the sample was determined to be 20W50. The car normally runs 10W60 Castrol TWS Motorsport synthetic.
      05-12-2008, 06:17 PM   #8
dbacon
Drives: 08 E92 Space Grey / Fox Red
I was told by my CA that there indeed was a different oil used during the break-in period.
      05-12-2008, 10:38 PM   #9
JAJ
Drives: 2014 Shelby GT500
The service booklet that comes with the car says that!
m3post
