BMW 5-Series (G30) Forum Wheels | Tires | Suspension | Brakes | Chassis KW Suspension for BMW G30 540i - KW Variant 3
      08-08-2017, 06:22 PM   #1
AutoTalent
AutoTalent's Avatar
2306
Drives: e92 M3 6mt | e60 M5 6mt
AutoTalent | KW Suspension | BMW G30 540i|
Applications: V3
Please PM or email: Golan@AutoTalent.com with any questions!
We are the oldest KW Suspension dealer!
KW V3: Adjustable Rebound & Compression Damping
Part # 352200BU
Want full control? The KW V3 gives you multiple settings for both rebound and compression. You have full access over ride comfort and handling to dial in that perfect setup. Race teams rely on adjustments to get that perfect lap time and having shock controls at your fingertips is key. KW V3 features -
Separate adjustments for compression (14 positions) and rebound (infinite settings),
Stiffer springs over stock for less bodyroll than the standard suspension,
Stainless steel strut/shock bodies and composite spring perches for superior corrossion resistance,
Individually height-adjustable:
Front: 0.8 " to 2.2 "
Rear: 0.8 " to 2.0 "
TUV approved lowering range and operation,
Expert engineering and design for ease-of-use and long durability,
Whether you track the car often or only use it for backroad carving the V3 will give you the tools to set up an ideal handling condition. You can crank it up for smooth and fast surfaces or soften it for city or rough roads. Since each shock is 2-way adjustable you can alter the front-rear balance to account for brake dive or squat during power application coming out of the corner. You are in total control!
Coil over suspensions are better engineered suspension options compared to a standard shock + spring package. Since the springs and shocks in a coil over are designed by a team of engineers to work together, there is much better suspension travel and more precisely tuned specifications for spring and shock rates. Using separate shock and spring specs may result in premature coil bind or shock bottoming. And most coil over kits offer more features than the traditional packages. Coil overs are also more useful when larger wheels/tires are used because you can precisely set the ride heights to clear the new tires.
      08-09-2017, 06:28 PM   #2
remmib
remmib's Avatar
Norway
1566
Drives: 2013 F10 520d M-Sport
Any words on coilovers for the xDrive?
I imagine the demand for coilovers for xDrive G30's should be high since the M550i is now xDrive only and some markets only sell xDrive cars of some or all models.
      09-07-2017, 05:14 PM   #3
AutoTalent
AutoTalent's Avatar
2306
Bump!
      09-08-2017, 09:38 AM   #4
dredre6429
Drives: 530i touring
G31?
      01-08-2018, 06:52 PM   #5
AutoTalent
AutoTalent's Avatar
2306
Bump!
      01-25-2018, 12:58 PM   #6
AutoTalent
AutoTalent's Avatar
2306
Bump!
      01-29-2018, 07:12 PM   #7
AutoTalent
AutoTalent's Avatar
2306
Bump! KW suspension for the G30 is ready to go!
      02-07-2018, 10:00 PM   #8
AutoTalent
AutoTalent's Avatar
2306
Bump!
      05-10-2018, 03:28 PM   #9
AutoTalent
AutoTalent's Avatar
2306
Bump!
      05-17-2018, 07:10 AM   #10
delrosa81
Delrosa81
delrosa81's Avatar
Singapore
59
Drives: G30 540i M Sport
How about the G30 with adaptive suspensions? Does KW have a model with adaptive dampers that can work with the inbuilt control systems?
F20 LCi
      05-17-2018, 02:35 PM   #11
AutoTalent
AutoTalent's Avatar
2306
The only kit that would work with the EDC from the factory would be the KW DDC kit which does not currently have an application for the G30.
      05-17-2018, 04:22 PM   #12
SteveMondragon
Seaman
SteveMondragon's Avatar
Drives: E92 | I01 | G30
Are these only for the 540i? Or will these work on any G30 chassis non x-drive car?
I realize the spring rates may differ between chassis, but wondering if there's any other physical difference from making them fit a 530.
      05-20-2018, 07:04 PM   #13
delrosa81
Delrosa81
delrosa81's Avatar
Singapore
59
Thanks for the info Auto Talent. Guess the G30 platform is still rather new for now.
F20 LCi
      05-21-2018, 03:00 PM   #14
AutoTalent
AutoTalent's Avatar
2306
It says they will work on either G30 chassis with non x-drive. Part # is 352200BU.
      06-26-2018, 05:28 PM   #15
AutoTalent
AutoTalent's Avatar
2306
Bump!
      08-13-2018, 04:43 PM   #16
AutoTalent
AutoTalent's Avatar
2306
Bump! We are a PM away or you can visit our site by clicking HERE!
      09-13-2018, 01:03 PM   #17
AutoTalent
AutoTalent's Avatar
2306
Bump!
      11-05-2018, 04:35 PM   #18
AutoTalent
AutoTalent's Avatar
2306
Bump! Let me know if you have any questions.
      11-21-2018, 05:48 PM   #19
AutoTalent
AutoTalent's Avatar
2306
Black Friday Sale on KW Suspension! Use code "MBBF" on our website in the checkout!
      12-12-2018, 09:16 PM   #20
AutoTalent
AutoTalent's Avatar
2306
Bump!
      01-03-2019, 12:58 AM   #21
AutoTalent
AutoTalent's Avatar
2306
bump!
      05-22-2019, 08:49 PM   #22
AutoTalent
AutoTalent's Avatar
2306
Bump! Sale valid until the end of the month!
