08-07-2017, 06:41 AM | #1 |
Rep 5
2018 F30/32 LCI rear fog coding
Has anyone figured out how to code the rear fog lamp function for the new 2018 F30/32/82 LED tail lamp clusters? Please note that these are not the same as Euro LED tail lamps already discussed in this forum; they have different reverse lamp sections and no apparent fog section, but it must be there if this version is now standard on the same 2018 cars in Europe.
I was able to make the correct headlamp switch modification (grind off 3 tabs) and did the coding that worked on my old 2015 F32 [For reference: FEM -> 3060 -> NSL_Verbaut (Value= Verbaut) REM -> 3063 -> Mapping_Nebelschlussl_L_output (Value = nsl_l) REM -> 3063 -> Mapping_Nebelschlussl_L_function (Value=nebelschlusslicht) REM -> 3063 -> Mapping_Nebelschlussl_R_output (Value = nsl_r) REM -> 3063 -> Mapping_Nebelschlussl_R_function (Value = nebelschlusslicht)] The yellow fog lamp symbol lights in the instrument cluster, but nothing happens in the tail lamp. Picture of new 2018 tail lamp is attached, and can also be seen at: http://www.motortrend.com/2018-bmw-4...pe-tail-light/. Thanks a lot for any ideas! |
08-12-2017, 05:28 PM | #2 |
Rep 5
2018 BMW F30/32 rear fog coding SOLVED
Answering my own question, after a bit of experimentation, I was able to program the outer (fender) turn signal lamps as fogs, as follows:
FEM -> 3060 -> NSL_Verbaut (Value= Verbaut) REM -> 3063 -> Mapping_Nebelschlussl_L_output (Value = 0x20) REM -> 3063 -> Mapping_Nebelschlussl_L_function (Value=nebelschlusslicht) REM -> 3063 -> Mapping_Nebelschlussl_R_output (Value = 0x21) REM -> 3063 -> Mapping_Nebelschlussl_R_function (Value = nebelschlusslicht) Everything else works as before. This also works for F82. As everyone says, "Do it your own risk." Now, does anyone know the coding for the inner (trunk lid) turn signal lamps? Experimentation got me nowhere -- perhaps there is a "dependency", , , |
08-12-2017, 11:57 PM | #3 | |
Rep 1,509
Funny... I had just taken pictures of my car and was planning to post them with a similar question.
I tried changing values to the ones you listed: Quote:
I have a 2018 440i with every option except track handling, headlight washers and heated steering wheel. |
09-25-2018, 01:14 PM | #6 |
Rep 198
09-25-2018, 09:18 PM | #7 |
Rep 1,509
Never got it to work.
InstigatorX58.00 |
03-03-2019, 04:30 AM | #9 |
Rep 1,509
Finally got it to work using BimmerCode. I could never enter the hex codes with esys.
I would prefer to use the inner turn signals for fog lights. Anybody know the value? |
06-30-2019, 06:19 PM | #10 | |
Rep 2
Realize this thread is a bit old, but did you ever get the inner trunk lid fog lights to work? I have the same issue. Thx |
07-08-2019, 01:52 AM | #11 |
Rep 1,509
07-09-2020, 01:13 AM | #12 | |
Rep 1,509
Finally! Thanks to a recent post on the F82 forum, I was able to add the inner lights as fog lamps.
REM -> 3063 -> Mapping_Nebelschlussl_L_output (Value = 00x1A) REM -> 3063 -> Mapping_Nebelschlussl_R_output (Value = 00x1B) If you're using Bimmercode, just enter the values as 1A and 1B, without the leading 00x. Quote:
02-08-2021, 09:13 PM | #15 |
Rep 245
Could anyone please help. I've coded the following below, no luck. When I pushed the rear fog light button, no indicator light for rear fog light on the dash lit up. Using esys and no errors during the coding process.
FEM -> 3060 -> NSL_Verbaut (Value= Verbaut) REM -> 3063 -> Mapping_Nebelschlussl_L_output (Value = 1A) REM -> 3063 -> Mapping_Nebelschlussl_L_function (Value=nebelschlusslicht) REM -> 3063 -> Mapping_Nebelschlussl_R_output (Value = 1B) REM -> 3063 -> Mapping_Nebelschlussl_R_function (Value = nebelschlusslicht) Note, reason I edit value to 1A and 1B, because 00x1A and 00x1B were invalid when saving. Btw, I'm trying to code my F32, that is MY2020 LCI. |
02-08-2021, 09:19 PM | #16 |
Rep 245
Same situation, can't seem to decipher the hex code using esys.. Gotten far enough to modify the rear fog light button but wonder if others could share what they did using esys.
01-13-2022, 08:09 AM | #17 |
Rep 1,758
The US spec all red inner tails do not have the rear fog lamp LEDs installed. I bought the blackline Euro ones which I think look better anyway. Worth it.
2016 428ix, r, 2018 430iC, 2018 330it
1QuikWS61621.50 |
01-13-2022, 08:15 AM | #18 |
No 55mph
1622
Rep 8,476
Same here
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
amancuso725.50 |
04-28-2023, 07:35 AM | #19 |
Rep 1,758
Does anyone know how to code the LOWER INNER tail light to act as the rear fog?
