08-05-2017, 01:51 PM | #1 |
Rep 254
Drives: 2019 Black 330i xDrive
ISTA+ vs ESYS?
I did a quick search on the forums and couldn't find a comparison or any really in depth explanations. I already have ISTA/D installed for the factory service manual and diagnostics but I was under the impression that ISTA-P was the programming and coding application, however on most the coding stickies and posts, everybody is just using ESYS. So what exactly is the purpose of ISTA-P and how does it differ from ESYS?
I have windows 10 successfully booted from and external HD and running dual boot on my MacBook. I also have an ENET cable as well. I want to begin programming soon but want to know exactly which program to use. Thank you!
2019 G20 Black 330i xDrive
08-05-2017, 11:52 PM | #2 |
Rep 254
Bump
08-06-2017, 03:58 PM | #3 | |
Rep 8,364
08-06-2017, 04:11 PM | #4 | ||
Rep 254
08-06-2017, 05:12 PM | #6 |
Rep 254
Thank you! That's what I needed! Guess I installed the 100+ gig on my hard drive for no reason. Lol oh well
08-06-2017, 05:16 PM | #7 |
Rep 8,364
08-06-2017, 05:22 PM | #8 | |
Rep 254
08-06-2017, 07:21 PM | #9 | |
Rep 8,364
Aevintiri97.00 |
08-06-2017, 08:58 PM | #10 |
Rep 5,776
ISTA is not useless as it is great for checking codes on the car and looking up remedies. I use Esys for coding but hook up ISTA to get the best checking of codes as I have found my JB4 and Carley to not be as accurate and specific.
2013 335i Msport Black sapphire/Coral red. MHD. stage 2--e30 VRSF DP, ER CP, Dinan Shockware. VRSF 12mm/15mm spacers. Cobra dashcam. Various codings.
Last car: 2011 335i Msport. JB4. Vrsf CP |
08-06-2017, 09:16 PM | #11 |
Rep 8,364
ISTA-P is not for checking errors.
08-06-2017, 09:26 PM | #12 |
Rep 5,776
Ahhh..didn't know there were different ISTA's...guess that is what the P stands for, programming?
08-06-2017, 09:57 PM | #13 |
Rep 8,364
08-06-2017, 10:00 PM | #14 |
Rep 254
Okay thanks! You've been a huge help!
07-30-2018, 03:32 PM | #16 |
Rep 34
ISTA+ vs ESYS?
Hi there, I have a question too if you don't mind
I've been programming with E-sys/enet cable and until now it's been great, retrofitted 6WA and now I need to diagnose why my cruise control stopped working Is this something I can diagnose with ISTA? Do I need a different cable? I have a feeling I need to update firmware, is that possible? Any help will be appreciated |
07-30-2018, 05:42 PM | #17 | |||
Rep 2,302
Did the problem occur right after the retrofit? |
07-30-2018, 06:01 PM | #18 | ||||
Rep 34
07-31-2018, 12:33 AM | #19 |
Rep 8,364
07-31-2018, 01:17 AM | #20 | |
Rep 34
Can I use esys to flash the ecu? Anything I should know before I attempt a flash? Sorry for a lot of questions but I need to research how before I'm comfortable attempting it |
08-03-2018, 10:43 PM | #21 | |
Rep 8,364
ZGW can be tricky. You may need router or program that serves as one. Never apologize for asking questions before flashing; there is much risk involved and you should be knowledgeable and prepared. |
09-02-2018, 09:12 AM | #22 | ||
Rep 34
So two things: - power supply, I understand I need to keep the voltage up whilst coding but can't have the engine running. A power supply I need is quite expensive, could I keep another car running and use jump leads to power mine? - router. You mentioned I need a router to flash a gateway, I'm guessing it's a normally configured router and it's the DHCP server I need. My question is the connections. Do I go from the car into the router, and from the router into the laptop? |
