07-30-2017, 04:41 PM | #1 |
Rep 4
NBT-EVO id5 coding
Hi!
I'm trying to replace my NBT EVO id4 by one used id5. I have just the headunit and I'll use my id4 (probably Apix1) display. I've installed navi activator to prevent locking the headunit and I already installed FSC's for my vin with USB drive. My only problem is that I don't have any signal on display (I have sound) but when I read SVT I can't read coding of NBT. There's no CAFD file under NBT. I've read somewhere that I have to use a modified FA but I I've tried without success. Does anyone has a modified FA.xml that I can use so I can code the display? Or am I doing something else wrong? Thank you for your great help!!!!! Best regards Mk |
02-21-2019, 01:39 PM | #4 |
Rep 6
02-25-2019, 02:11 AM | #5 |
Rep 61
Drives: M3F80-Frozenblack-metallic
03-03-2019, 02:54 PM | #6 | |
Rep 6
I have a question. Did you solve the above? Im having the same problem.. Thanks! |
03-26-2019, 08:17 AM | #7 | |
Rep 61
Just try your chassis and newer build. Check the special options for the navigation codes. Delete yours in the FA and set the ones you can find with NBT evo. Thats should be it. Make sure to just code the modules which are related to the NBT. No guarantee on that. Just my logical thoughts and some things I've read. |
03-31-2019, 05:12 AM | #8 |
Rep 36
Did you try detect CAF for SWE?
|Plug&Play USB FSC sets for NBT and NBT EVO ID4,5,6 - cheapest price on Bimmerpost forum - 40 POUNDS per pack| 18/11 remote FSC pack + CARPLAY FULLSCREEN - 50 POUNDS ONLY Lifetime MAP update codes NBT NEXT, CIC PREMIUM 10 pounds each Whatsapp for quick communication: +886908958631 |
