07-23-2017, 01:21 PM | #1 |
Rep 57
Car won't start after throttle actuator replacement?
So I just replaced one of my throttle actuators (diy) on my e90 m3 and I'm not sure wtf is going on..car drove perfectly when I drove it for a couple of miles after i replaced the actuator. I then parked the car for 20 mins then restarted it to a rough idle, rpm would go from 500 to 1000, then back to 500.
After I got home I noticed that I didn't properly install the intake plenum. Not sure if this is what caused this mess.. I pulled these codes today after starting it up Filmed a cold start this morning--》 Last edited by Hakaj; 07-26-2017 at 03:41 PM.. |
08-01-2017, 02:43 PM | #2 |
Rep 973
Drives: 2012 E92 M3 DCT ZCP
Hmm...perhaps a vacuum leak perhaps due to improperly seated plenum?
2012 E92 M3 | ZCP | DCT | Space Grey Metallic | Black Novillo | BE/ARP | MPE V2 | AA green filter |BMW CF Rear Spoiler, RW Carbon Diffuser, CF Front Splitters | DTEC 160W Angel Eyes
08-02-2017, 09:29 PM | #4 |
Rep 136
Your title says it won't start, but you describe rough idling?
First, as mentioned I'd suggest to retrace your steps and confirm all electrical connectors are seated properly
08-03-2017, 12:47 PM | #5 |
Rep 57
Soooooooooo my mechanic found a napkin in the idle control valve which caused this bullshit... What the fuck. I didn't mess with the ICV while changing my actuator so i have no idea how the hell that happened....
Car runs great now, $500 for 5 hours of labor down the shitter Last edited by Hakaj; 08-03-2017 at 01:07 PM.. |
08-03-2017, 12:51 PM | #6 |
Rep 57
At first the car would not start however i noticed that after letting the car sit for a while (5+ hours) The car would start with a very, very rough idle.
08-03-2017, 01:33 PM | #7 | |
Rep 3,988
08-08-2017, 01:21 AM | #8 |
Rep 136
I'm perplexed as to how that could have happened. When replacing the TVA I was able to lift most of the wiring harness and saw where the ICV sat, but I thought it was a closed system except for the tubing that connects to the plenum? Anyway, at least you got it fixed!
