07-19-2017, 12:20 PM | #1 |
Rep 82
Best Carly mods/codes for F30
Hi all.
What are the best mods to apply with Carly? Apologies if this has been asked before, could not find another post. Chris |
07-19-2017, 04:54 PM | #2 |
Rep 1,687
Drives: 2014 428i and 2018 X5
There is no best modification as everyone's wants needs and opinions are different.
Read the lists of available coding options and form your own decision
___________________ 2014 F32 428i M-Sport 2018 F15 M-Sport |
RoundelM31836.50 |
07-20-2017, 07:33 AM | #3 |
Rep 6,990
Drives: 15 F80 M3, 22 G01 X3 30i
Some of the more popular ones are:
1. Removal of speedometer "correction" 2. Addition of digital speed readout to list of parameters displayed via stalk button 3. Unlock doors at engine stop when auto-locking is enabled 4. Shut-off of electronics after engine stop when driver door opened 5. Enabling display of tire temperature and pressure in I-Drive Those are just a few - there are many, depending on your car's options and so forth.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
07-20-2017, 03:43 PM | #4 |
Rep 82
I have managed to code quite a few things now.
There are two that I cannot find which I'm sure should be available. - Shut-off of electronics after engine stop when driver door opened - Acoustic chime when locking/unlocking Can anyone advise? |
07-20-2017, 05:01 PM | #5 |
Rep 1,509
07-21-2017, 06:51 AM | #6 |
Rep 6,990
Are you referring to using Auto Start-Stop? In that case, it doesn't unlock; it only works when you push the engine stop button. And, if you have your unlock set to do driver-door only, that's the only door it will open. I try to avoid "sketchy areas" wherever I'm driving, and I have a concealed-carry permit as a further deterrent to any would-be carjackers.
07-21-2017, 05:43 PM | #7 | ||
Rep 1,509
Situational awareness is the key. If you're in a position where you are justified in using deadly force, your life is already in danger, and it could all be over before you have a chance to draw a firearm (especially if it is truly concealed, because drawing from concealment while seated and wearing a seatbelt takes a lot longer than drawing at the range). |
07-22-2017, 10:31 AM | #8 | |
Rep 6,990
The point of unlocking the doors at engine shutoff is convenience; in the past, some makes had the same feature when shifting into Park. Personal choice, which is why it's an option, not a requirement.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey Last edited by RoundelM3; 07-22-2017 at 10:51 AM.. |
