07-12-2017, 08:18 AM | #1 |
Dildo
12
Rep 119
Headlamp washers!!!!
Hi guys , so recently installed a aftermarket m3 style front bumper on my 2013 msport f30. Looks great but I'm having issues with the damn headlamp washers , they never go back to the perfect position , figures though because after market bumper. ANYWAYSSSS
Is there a way to deactivate the headlamp washer? code? or just pulling a fuse? thanks homies!
2015 435i Gran Coupe - M sport - Carbon black Rwd AT.
I like tacos |
07-12-2017, 11:20 AM | #2 |
Rep 53
Shouldn't be a problem, remove the VO code for the washers and code the ECUs.
VO for the washers should be 502. If you want/need to keep the washers I guess you could also take off the front bumper and attach the washer nozzle supports to the correct position, the incorrect installation is most likely why the nozzle covers don't go back correctly. However if the nozzle supports were glued down it might be impossible to remove them without breaking them. |
