07-04-2017, 10:54 PM | #1 |
Rep 117
Help! Brass hair from brush fell into throttle body!
Please help. I was trying to clean the throttle bodies today and was giving the shaft of the butterflies a gentle scrub while I looked down to see a brass hair sitting between a valve and wall.
I'm not sure if I'll be able to fish the brass hair back out. Worst case scenario, would I do any damage to the engine if I fired it up? |
07-04-2017, 11:32 PM | #2 | |
Rep 2,712
Drives: M3
Garage List 2016 BMW X5M [0.00]
08 BMW M3 [0.00] 14 BMW X5 50i - sold [0.00] 09 BMW 335i - Sold [0.00] 09 BMW 328i - Sold [0.00] 07 BMW 328i - Sold [0.00] |
Evolve, Eisenmann, Strasse, StopTech, Active Autowerke
07-04-2017, 11:34 PM | #3 |
Rep 266
If you haven't already I would try a vacuum cleaner. Then maybe something sticky on a pencil or something, be careful not to make it worse though.
If does go down a cold engine I can imagine it would be possible to go right out with no harm. Don't know what the odds are though. |
07-05-2017, 04:34 PM | #5 |
Rep 6,226
07-06-2017, 12:49 AM | #6 |
Rep 117
Problem is I was cleaning underneath the butterflies. Had to have it open like this:
White 13 Thanks for the suggestion on vacuuming it out! It didn't cross my mind during the panic. I had to improvise to get a tip long and narrow enough to get in there but I got it!!!! Last edited by ohhgourami; 07-06-2017 at 01:28 AM.. Reason: relink |
07-06-2017, 01:22 AM | #7 | |
Rep 6,226
07-07-2017, 03:55 AM | #8 | |
Rep 7,055
Thanks |
07-07-2017, 05:05 PM | #9 | |
Rep 117
I've got almost 40k on the car and it was pretty clean inside. There was some carbon dust around the butterflies but nothing major. As you can see, the top of the valves are completely clean. Then I realized one of my TVA's were seizing up so then I had to take out the TVA's to clean too. I made the mistake of putting teflon grease on the replacement gears which ended up gumming up from the high temps. Here's my replacement UKarauto (ebay) gears after 5k miles. I see absolutely no wear. I did preventative maintenance, not after the car started throwing codes. |
07-08-2017, 02:36 AM | #10 | |
Rep 7,055
07-08-2017, 02:51 AM | #11 | |
Rep 117
The UKar auto gears is brass on plastic. You can see that the center of that middle gear is brass. I just don't have a pic of the back side of that gear. At this rate, I'm expecting these to last a pretty long time as brass on plastic doesn't wear down easily. Do NOT put grease! Funny thing is after I put everything back together, I got a bunch of error codes. I've probably removed the TVAs a good 4 times in 2 days now. I forgot to align the 2 pins to the board when reassembling because I was in a rush At least I'm really good at taking it apart now. |
07-08-2017, 03:59 AM | #12 | |
Rep 7,055
