BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > Fitting a 4 pipe exhaust and a diffuser on a 114i
      06-27-2017, 03:22 PM   #1
JacobL
Drives: BMW 114i 2013
Hi guys.
Does anybody have experience with putting a 4 pipe exhaust on a 114i/116i/118i with an msport kit?
I have a 2013 114i with the msport kit and currently only one tiny exhaust pipe. I would like two dual pipes and a diffuser.
The problem is as follows:
An ordinary f20 has the pipe in the center of the panel on the left side of the number plate. Here is a two pipe specimen.
A m135i has pipes further towards the middle.
Any diffuser I can find made for 4 pipes have the hole somewhere between the hole on a 114i and a m135i.
It looks like 4 pipe exhausts are made to extend the holes both ways. Just like this m135i.
Here is a picture of the diffuser on a 114i.
As you can see a dual exhaust on each side will not fit the holes. Unless some manufacturer makes a version where the two pipes on each side are not centered around the original pipe. I havn't been able to find one.
Has anybody here done this before? Will I really need to chose if I want the 4 pipes or the diffuser?
      06-29-2017, 08:18 AM   #2
VESPER_125i
Australia
Drives: BMW F20 LCI 125i M-Sport
Go to a local exhaust shop and get a custom one so position of tips won't be a problem.
1addicts
