06-13-2017, 02:48 AM | #1 |
Rep 140
Remove horn sound when closing car
Since I have updated the software of the car, when I close it is started, it gives two beeps of horn, which it did not before.
I would like to remove it, since it draws quite the attention and I would like it to happen more unnoticed, maximum when I am leaving it with the engine in marcga. Do you know how to remove this? Thanks and regards. |
06-13-2017, 10:18 AM | #3 | |
Rep 140
Thanks for your help. In the Idrive I have never seen that configuration, my car has no alarm, what sounds in my case is the horn or horn and only when I close the car with the engine started, with the vehicle stationary does not sound either to open or close . Greetings. |
06-13-2017, 11:52 AM | #5 |
Rep 16,086
I assume you mean with the fob out of the car. If so that indicates that the new software wants to remind you that you left the car running, just in case you forgot. At my age that wouldn't be a bad thing. I can imagine leaving the car running while playing 18 holes of golf, returning to find an empty gas tank.
06-13-2017, 03:12 PM | #6 | |
Rep 140
06-13-2017, 03:13 PM | #7 |
Rep 140
06-13-2017, 03:33 PM | #8 | |
Rep 6,001
06-13-2017, 10:35 PM | #9 | |||
Rep 16,086
06-14-2017, 01:06 AM | #10 | |
Rep 140
I remember that both the e46 and the e90 could be made to sound the horn when opening and closing the car, had to add as an equipment the alarm (even if it did not) and then the horns could be activated ... |
06-14-2017, 01:11 AM | #11 |
Rep 6,001
My MY 2016 340i has alarm as standard, but does not utilize the horn even when the alarm goes off. It uses the chime that's used for lock and unlock but sounds it as a siren. Not as loud as the horn, which I would prefer. I can sound the horn remotely with the app.
06-14-2017, 01:22 AM | #12 | |
Rep 140
I think you could also play the sound level, it should come with different levels depending on the country's regulations. By memory in that I can no longer help you, but it is possible that it can also be modified in the F30 |
06-14-2017, 04:51 AM | #13 |
Rep 1,799
My 2017 F31 with iDrive 5 sounds the horn twice if I lock the car with the engine running.
With my previous 2015 F31 with iDrive4 the horn didn't sound if I locked the car with the engine running.
U06 230e Active Tourer |
Previous : 2019 F31 340i : 2017 F31 335D M-Sport |
06-15-2017, 01:12 AM | #15 |
Rep 140
11-21-2021, 06:43 PM | #16 |
'11 N55 335ix sport, '00 M5, '88 M3
Rep 8
Excellent info. Thanks!
Mine has the standard alarm activate/deactivate audio when locking/unlocking with the engine off, but like the OP, it sounds the horn twice when locking with the engine running. This will be a welcome change. I wouldn't mind if it was the alarm activate audio, but the horn is irritating and loud. Thanks again! |
11-23-2021, 07:38 AM | #17 | |
Rep 140
I'm glad it was helpful. Last edited by jaco_ma; 12-02-2021 at 02:37 AM.. |
12-05-2021, 02:18 AM | #19 |
from Georgia
Rep 6
