Change from Single Exhaust Tip to Twin Tips
02-26-2006, 11:34 PM | #1 |
Rep 37
I recently bought 320i Executive (in Australia) but the car hasn't been delivered yet.
It has a single chrome exhaust tip but I am just wondering if I can install twin exhaust tips (either aftermarket or OEM). If anyone has an idea, please advise. Regards, aussie79 |
02-27-2006, 04:11 AM | #2 |
Rep 326
Drives: G05 X5 30d, Boxster GTS (981)
No you can't just install the twin exhaust tips. You'll need to install the whole exhaust to get it. You can probably do it, but it might lower your car's power.
02-27-2006, 04:18 AM | #3 |
Rep 138
Buy a Remus, Eisenmann,Hartge or Acschnitzer exhaust and youll get twin pipes, and this will also give a nice sound.
Bmw 325i -06 "Slush o' matic"
20" Hartge classics with Falken 245/30 and 285/25*Eisenmann race 2x76mm*K&N Euro cone filter*H&R Cupkit race*Oem Front and Rear spoiler* Xenon led rings*Blacklines* |
02-27-2006, 07:50 AM | #4 |
Rep 326
I haven't heard a good exhaust sound on the 320i.
I wonder how Remus will sound. If you are going for sound, i'd go for GruppeM first. |
02-27-2006, 10:24 AM | #5 |
Rep 138
Which exhausts have you heard?
02-27-2006, 11:18 AM | #6 |
Rep 498
Drives: E90 325i
Funny I was thinking of doing the same thing. Will this void the warranty if I just change the single tip (just the tip) with an aftermarket twin tail pipe type?
02-27-2006, 04:30 PM | #7 |
Rep 37
Hey, my intention is just to make it look good with twin tips.
Will the aftermarket twin tip do? (is it recommended anyway?) Obvisouly twin chrome tip will look far better.... help me out.. |
02-27-2006, 04:48 PM | #8 |
Rep 326
i've heard supersprint, arqray, and bluewave and another one which I don't remember. My friend kept on changing the exhaust cause it sounded just like the OEM and just gave up.
I wonder how eisenmann would sound like though. Spending 1000 dollars just for the looks of a twin pipe is IMO a bit too much. |
02-27-2006, 05:43 PM | #9 | |
all systems are go
Rep 157
02-27-2006, 05:49 PM | #10 | |
Rep 3,566
Drives: F30 M-Sport 328i Estoril Blue
328i M-Sport, Estoril Blue, Carbon XP 35 Tint, front heated seats, black Dakota, Sports Suspension, Anthracite Headliner, HUD, Pro Nav, Sunroof, hk 600w, Bi-Xenon, 19" 403M wheels, Reversing Camera, DAB+, Xenon, BT Ext Connect, MST turbo intake pipe, MST Cold Air Intake, JB4 on Map 2 with Catless DP produces awesome performance in Sport.
06-19-2006, 09:24 AM | #11 |
Rep 8
Hello all ,
I am a new member and will be a new e90 owner in 1 week It make a bit more than one month that I am waiting for my new car, this start to make long... I did post a question similar to the one of this thread in an other forum section but obiviously there are less forum members visiting this part of the forum My e90 is a 320d without particle filter and as mentioned by other owners the downturned exhaust is not that nice. So I am planning to change it and I was starting to look for aftermarket exhaust tip, only issue my dealer is quite far from my place and there not that much e90 were I live, so I could not find the size of the stock exhaust of the 320d... Could some one tell me the diameter of the exhaust tail pipe if he knows it or may be go to his car and measure it for me, that would be very nice I found a picutre on the internet showing the exhaust of 320d (or a 320i) from the bottom apparently the pipe becomes oval only at the end so the diameter of the pipe might be smaller few centimers before the end of the pipe. If I cut the downturned end I might end up with a circle and not an oval. You can see it on the picture. I am also planning to put a Y connector to have twin exhaust tip, look's better for me. I don't know what size would be the best I don't want something too big... I was thinking of 2* 70mm or 2* 76mm. Can you show me some pictures of a e90 with that kind of aftermarket exhaust tips? I think on the 330 by default it is 2* 70mm? Thank you in advance for your replies!
320d Black Sapphire with 159 rims, sport seats, sport suspension
06-20-2006, 08:22 AM | #12 |
Rep 8
Hello
I went to a shop for aftermarket exhaust tips yesterday evening and I found 2 of them that looks good and are good quality product. one is 2 * 70mm (2.75 inches) and the other is 2 * 76mm (3 inches) The issue is for the inlet size, those tips are made for pipe of max (63 mm) 2.5 inches, and i still don't know the size of the pipe on the 320d e90. It would be very nice is someone with a 320d or 320i could measure the pipe max diameter (before it becomes an oval) on their car.
06-21-2006, 10:52 AM | #13 |
Rep 8
Hello!
No one to help me I might be able to measure the exhaust on my own this week end but I would have like to know the diameter of the pipe earlier and may be also have some advices on the kind of exhaust tip I should go for... Thank you for your help
06-24-2006, 02:38 AM | #15 |
Rep 23
Me as well I will soon received my 320d and I don't have the particle filter.
I would also be interrested by some more information on an exhaust tip. If you find some answers or do it please post the pictures on the forum Thanks!
My first BMW:
320d Saphirschwarz metallic + 159 rims + sports suspension |
06-24-2006, 03:47 AM | #16 |
Torque junky
115
Rep 1,688
Drives: Remapped e90 330d
The single exhause pipe on the 320d without the particle filter is turned downwards, meaning that fitting a generic aftermarket straight tip is almost impossible. Having the particle filter helps, but only a bit, because although the tip is straight, it is large and oval shaped. Cutting off the particle-filter pipe before it becomes oval is a possibility, but I think you will need an extra long tip.
Another way to get round the problem is to fit a new backbox with straight round tips. I did this on my old e39 530d, but I wasn't entirely happy with the result (it looked kind of artificial and the smoke was more visible when I accelerated). There will also be issues with the contrôle technique, because non-filter diesels must have downturned pipes in the EU to be road legal (I sold my e39 before I was required to take the test, so I never found out if this was a serious issue or not). With a bit of luck, BMW will eventually realise there is a lot of demand for this conversion and bring out an aftermarket solution. The 330d has a particle filter and twin chrome tips as standard.
www.greenkeepers.fr - spécialiste des tondeuses à gazon hélicoïdales atco qualcast ransomes lawnflite
06-25-2006, 03:35 AM | #17 |
Rep 23
Thanks for your reply!
I was to my dealer yesterday and I asked him about the exhaust pipe. He will check if this will have an impact on the waranty if they cut the downturned part and plug a tip at the end. My dealer should come back to me begining of next week with his findings... I hope he will have good news. I will let you know. Other good news is that my car will be ready in advance I can take it the 3rd of July 8 more days to wait and then
My first BMW:
06-25-2006, 07:27 AM | #18 |
Torque junky
115
Rep 1,688
It probably won't affect the warranty, but it will be a problem when the time comes for the contrôle technique (if you still have the car then).
06-25-2006, 10:34 PM | #19 |
Bimmer Manual all the way
66
Rep 1,811
hi . i had the same keeness as yourself to change that UGLY stock 320i oval pipe, even after i put chrome tips on it. i chose the cheapest option. i cut the rear pipe and soldered a y connector -aftermarket to get the twin look. This is purely cosmetic , but looks great. will be getting my m rear apron and diffuser soon to complete my rear look with ACS boot lid spoiler and kerscher front bumper
06-26-2006, 02:07 AM | #20 |
Rep 23
Thanks for the pictures
This looks good, I think i will do something similar. Do you remember what was the size of the inlet of the exhaust tip you did use? I have found some tips that accept up to 63mm: http://www.larkspeed.com/index.pl?a=...TIP&p=28FT7124 I think those are the same kinds of tips that frank the rabbit is looking for as well. This is about 2,5 inches, do you think this could fit on the e90 exhaust? I believe if we cut the very end of the exhaust the 320d and the 320i got the same diameter Thanks again for the pictures and your advice, I come back to you whan I got news from the dealer. About the "controle technique" I think I will sell the car before 4 years anyway so it should not be an issue and if I keep it longer then I will have time to find a solution!
My first BMW:
06-26-2006, 02:29 AM | #21 |
66
Rep 1,811
sorry, guys. i found out about this cheap mod when i visited my bmw dealership and saw a chap with another 320i with the same mod. promptly went to the same place/exhaust shop in singapore and did exactly the same mod. did not take down an measurements. quite cheap -50US bucks for labour and y connector pipe.
06-26-2006, 02:37 AM | #22 |
Rep 2,916
hi there,,,
im another 320i owner, n was thinking of changing the tip as well.. so maybe the best way is to go for aftermarket y connector?? cuz in the end i just want look, ill bother myself with exhaust systems later
19" velocity CSL replicas staggured // Continental sport contact 2: rear: 255/35/19, Front: 235/35/19 // Blacklines // rear OEM spoiler // y-connector // 30% v-kool tint all around // Black Roof/Mirrors // H&R Sport springs // H&R TRAK+ 15mm spacers // BMW never makes ordinary cars . . . |
