Real carbon fiber skinning, alternative to resin?
06-05-2017, 09:05 AM | #1 |
Rep 1,002
For months now I have been debating with my self what to do with my plastic silver interior trim to make it look good. I have carbon fiber vinyl wrap on it at the moment but not too pleased with it. I am not a fan of the real carbon fiber trim either. I don't really like the "wet" look that the thick layer of resin gives to it. But last night I had a new idea - what if I stick a layer of carbon fiber on it (as you do when skinning) but don't apply any resin, instead spray it with a thin coat of some clear coat so the cb pattern texture remains exposed. The problem is I have never worked with carbon fiber, never even seen the cb fabric, and I have no relative knowledge at all(clearcoat sprays etc). What do you guys think? Can it be done and what would it work look wise? And what can I use for the clear coat?
Ta! |
06-05-2017, 04:50 PM | #3 |
Rep 1,002
I have crappy looking vinyl, but I bought some of the 3M and did one trim piece with it. It's better but not good enough for my liking. Plus it's quite rigid and wrapping it perfectly around all corners is almost impossible.
06-06-2017, 12:45 AM | #4 |
Rep 3,131
Drives: 2011 335i e92 DCT
Just put a light resin coat on? Doesnt it need the resin to strengthen the CF sheet.
/ MHD Stage 2+ / AR CATLESS DP / PE MOD 4 INCH TIPS / BMR FMIC / K&N DROP IN / BMS CP / |
06-06-2017, 02:28 AM | #5 |
Rep 1,002
Watching Youtube videos that resin looks quite thick and gooey. Applying a thin coat would be impossible. As for strengthening... it's interior trim, doesn't really need strength. I'm going for looks here.
06-06-2017, 02:03 PM | #6 | |
Rep 1,735
Looks and feels good.
|instagram@underground6t9| |
06-06-2017, 04:36 PM | #7 |
Rep 1,002
But I am not asking about 3M Di-Noc, I am asking what with I can spray the real carbon fiber skin to give it a thin clearcoat. Ideally something that will not crack as that plastic trim does flex somewhat.
06-08-2017, 02:04 PM | #8 |
uber driver
114
Rep 657
Couldn't you use resin, but finish it with a matte clear coat? Or would that hide the texture completely?
Seems like it's time for you to buy a small CF set to experiment! |
06-08-2017, 02:13 PM | #9 |
Rep 1,681
Maybe look into carbon fiber look fabric. They used to sell it as an alternative to vinyl - it's not real carbon but looks like it and doesn't have the shine of wet CF. You use 3M spray adhesive and other than that it wraps similar to vinyl.
Not sure if spraying clear coat on actual carbon fiber would be enough to keep the threads from separating during use. You can always try buying some carbon and spraying clear on it to see what happens. It would be cheap enough to experiment. I've messed with CF before, but never tried clearing raw carbon. The way they get the matte look on real CF is impregnating the fabric with resin and then setting it under vacuum. Not really feasible for what you're trying to do. |
06-09-2017, 08:02 AM | #10 | |
Rep 1,002
I was hoping this wasn't a new idea and someone had already tried this but looks like I will have to do my own experimenting. |
06-09-2017, 08:06 AM | #11 |
Rep 1,002
06-09-2017, 06:44 PM | #12 | ||
uber driver
114
Rep 657
