Further down the rabbit hole.....
06-03-2017, 08:34 AM | #1 |
Rep 166
I posted a little while back about a misfire issue I was having and my 335i has decided to take it another step further which really has me nervous and scared of what could possibly be wrong.
Here was my last thread which contains all info up until this point.... http://www.e90post.com/forums/showthread.php?t=1387734 This morning, I started my car to leave station and the car idled the worst it had ever. I gave the gas a couple blips and it essentially did nothing. White smoke pouring from tailpipes, absolutely wreaking of fuel. I hoped the computer would adjust and tailor it back, went from a string of really warm days to a cool morning. In a couple minutes, thought it was odd that condensation was already dripping from the exhaust tips. On a closer inspection it was fuel. In another minute, fuel was literally running out of my exhaust. Shut the car off and left it as I headed to work at another station. Any one have ideas on why my car would seemingly run richer and richer and richer to the point fuel is basically being pumped through the entire car like a gas station? A few datalogs from a week or two ago and a back story are in that thread I linked. Thanks in advance guys. Trying to fix this on my own since now is not the best time to spend the money to take it somewhere. About to lay it up in the garage and get ready to have to do some major work if that's what it comes to....... |
06-04-2017, 12:20 PM | #2 |
Apprentice
373
Rep 801
OP,
My 335i had the same exact issue when my fuel injectors went bad. Fuel was literally dumping out of the exhaust and it smelled awful and LOTS of white smoke. When my fuel injectors were going out, it was hit and miss. One day, the car would start up just fine, drive fine, idle fine, no SES light. Other times, it would idle terribly and this is when the fuel was spilling out of my exhaust with a ton of white smoke. My Indy didn't go into details but told me when you have fuel like that coming out of the exhaust as well as terribly rough idles, it is almost every time going to be your injectors. I don't think there is a physical way of testing the injectors other than reading your codes thrown. The misfires that you are getting on the codes points to your injectors. Also, there is a chance that your O2 sensor could be bad because of the excess of fuel getting dumped into the exhaust(I believe this sensor runs somewhere in the exhaust although I could be wrong there). Change your fuel injectors and report back. I am almost sure that's the culprit. |
06-04-2017, 03:16 PM | #3 | |
Rep 166
I'll order a set. I have been looking around and it seems the only legit ones I can find for a decent price are on FCP euro. If I remember correctly, they were approximately $850 for six, index12. Any other sources I should consider? Thanks! |
06-04-2017, 04:58 PM | #4 | |
Rep 405
06-04-2017, 05:59 PM | #5 | |
Rep 166
I am leaning toward FCP. |
06-04-2017, 06:03 PM | #6 | |
Rep 405
Add to your cart then price.fcpeuro.com |
06-04-2017, 09:22 PM | #7 | |
Rep 220
Might be talking out my butt here but is this still a thing? edit: here's a thread with the PDF. Only from 4/2007 to 10/31/2008. I'm in that range (barely, build date of 4/11/07), can't tell if you are or not. http://www.e90post.com/forums/showpo...0&postcount=28 Last edited by CantComplain; 06-04-2017 at 09:38 PM.. Reason: link to recall thread |
06-05-2017, 03:56 PM | #10 |
Rep 235
OP do you have INPA program? The new injectors will need to be coded to the car after they are installed.
Current Car: 2015 Tanzanite F80 M3 w/ Cohiba Brown Interior
Past Cars: Le Mans Blue 2010 e92 335i M-Sport 6MT // Cobb // BMW Performance Exhaust // AFE DCI Stage 2 // ER CP // Gloss Black BMW Performance Spoiler Rep // BMW Performance Black Grills // 19" Black Avant Garde m359s // TGS HPB LED Interior Kit |
06-05-2017, 04:34 PM | #12 |
Rep 166
I don't believe I have the INPA program. Is that something I can download? I only know that I have the PROcede software......
Thanks Ozzie! Ironically, I was planning on changing the oil during all this. Thanks for the heads up. I'm gonna get a crow foot for the O2 sensor tomorrow and get that swapped out. I need to order injectors tonight. |
06-06-2017, 09:27 AM | #13 |
Rep 166
Just got the O2 sensor in. Should I take the car out for a ride, or how should I go about checking if the O2 sensor fixed my issue? The old one was CAKED with buildup. I don't want to ruin this new one.
06-06-2017, 10:08 AM | #14 |
Apprentice
373
Rep 801
OP just change the injectors. The O2 sensor isn't the root cause of your problems.
06-08-2017, 07:56 PM | #18 |
Apprentice
373
Rep 801
06-09-2017, 07:55 AM | #19 |
Rep 166
Thanks jeddo. Washer pump replaced, tested and working, brakes changed, o2 sensor in, side skirts realigned, oil getting changed today, wheels cleaned inside and out, air filters washed and oiled, and any protective panels pulled have been scrubbed and washed. 😏😏😏. Feels good to get in there and take care of a lot of little things that have been nothri g me or allow me to take care of some miscellaneous issues.
Also found some loose and missing screws so good to get those handled. Come on injectors! Any harm in me pulling the old ones now while I wait? |
06-09-2017, 08:31 AM | #20 |
Rep 460
Our one 335i E92 has a build date of 3/7 too. I ended up replacing all 6 injector with index 12's. They were original index 1. The car ran great for 6 months then started acting up again. Rough running, misses etc,. My indy was afraid to touch it because they thought it was the DME.
I ended up taking it to the BMW dealership and they confirmed it was a bad MDS80 DME. Almost $3K later and with a new MDS81 DME the car has never run better. In your case hopefully it is just the injectors. The 2007's seem to be more trouble prone. The car now has 88K miles on it. Best of luck. |
06-13-2017, 04:52 PM | #22 |
Rep 166
Good news, injectors have arrived. Bad news, I had to work today.
So tomorrow night I am hoping to get them installed and then I am just waiting on the coding cable. One question I have as I looked through the DIY, it says something about if you have a piggyback system you need to put it in full bypass mode. I have a PROcede 2.5, is that a piggyback system? I have the program on my laptop for it if so and can probably find whatever it is I need to but I figured I would ask if this is technically a piggyback system. Thanks and can't wait to have her back on the road. |
