F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > How to change the number of flashes of the flashers?
proTUNING Freaks
      06-02-2017, 01:44 AM   #1
jaco_ma
jaco_ma's Avatar
Spain
28
Drives: G20 320d
Exclamation How to change the number of flashes of the flashers?
After passing the car through BMW and realizing an update of the DDE all my codifications were erased to me.
I have been able to do all of them again, except that I can not activate the 5 flashes of one-touch indicators.
I have a Level of Integration F020-17-03-505 right now.
I have tried with:
FEM_BODY 3060 BLINKZYKLEN_ANZAHL_TIPP werte = 04
And also with:
FEM_BODY 3069 PIA_DEFAULT_TIPPBLINKEN werte = 02
And nothing, in fact the second option when I re-enter to check the selection, after having coded the car, I have not kept the change of the Werte, yes in the first but not in the second.
I have used v.61.4_PSdZData_Lite.
Any ideas?
Thanks and regards
      06-02-2017, 05:35 PM   #2
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
No longer works on your I-Step.
      06-04-2017, 04:03 AM   #3
jaco_ma
jaco_ma's Avatar
Spain
28
Drives: G20 320d
And that's due? Do I need more modern PszData?
      06-04-2017, 12:15 PM   #4
Almaretto
Almaretto's Avatar
2374
That is due to new firmware on vehicle. Changing computer PSdZ will have no affect unless you cannot read vehicle; still will not allow you to code desired function.
jaco_ma28.00
      06-04-2017, 04:16 PM   #5
jaco_ma
jaco_ma's Avatar
Spain
28
Drives: G20 320d
With the old Firm I had it active.
So although if it is not because of the PSdZ, what should I expect to be able to activate it again?
A greeting.
      06-04-2017, 08:14 PM   #6
Almaretto
Almaretto's Avatar
2374
A greeting.
Like I said, starting with P3.61.1, that function could not longer be controlled with same coding. That is why coding no longer had any effect after update.
I have no idea why it was changed; only BMW AG knows. As such, there is no way to know if and when it may be able to be coded again. If function is that important, you may have to download firmware.
      06-05-2017, 04:02 AM   #7
jaco_ma
jaco_ma's Avatar
Spain
28
Drives: G20 320d
Okay.
It's not that it's vital, but I did like some flashing. We will have to wait and see if they can find it in the modern Firm.
Thank you for everything and greetings.
      06-13-2017, 10:14 AM   #8
jaco_ma
jaco_ma's Avatar
Spain
28
Drives: G20 320d
I resign myself to think that there is no way to activate the 5 flashes with a touch ...
      06-24-2017, 02:16 PM   #9
jaco_ma
jaco_ma's Avatar
Spain
28
Drives: G20 320d
No one has done it in a current F30?
      07-23-2017, 04:35 AM   #10
jaco_ma
jaco_ma's Avatar
Spain
28
Drives: G20 320d
We still have no solution?
      07-23-2017, 01:47 PM   #11
Almaretto
Almaretto's Avatar
2374
Correct.
jaco_ma28.00
      07-23-2017, 01:54 PM   #12
jaco_ma
jaco_ma's Avatar
Spain
28
Drives: G20 320d
Correct.
A pity, we'll keep waiting ...
Thanks for answering!!
      07-23-2017, 07:34 PM   #13
Almaretto
Almaretto's Avatar
2374
      07-24-2017, 06:49 PM   #14
RSnic
RSnic's Avatar
Drives: 2020 M340Xi (G20)
2020 BMW M340  [0.00]
ALmaretto,
Indeed, that is a real bummer!
BUT what you point out only applies if the car has been reprogrammed by dealer or is an ECU has been flashed with the newer PSdZ data -- CORRECT?
If you just use the PSdZ data for coding, it'll still work -- CORRECT?
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH|
Retired: 2014 328i
BMW CCA
      07-24-2017, 07:38 PM   #15
Almaretto
Almaretto's Avatar
2374
Originally Posted by RSnic View Post
ALmaretto,
PSdZ on computer must only be > vehicle I-Step. The firmware on vehicle is what limits functionality. As such, if car has < P3.61.x, then coding will work.
      07-25-2017, 01:09 AM   #16
jaco_ma
jaco_ma's Avatar
Spain
28
Drives: G20 320d
The vehicle has been updated the Soft in a BMW dealer, which has a higher Integration Level than when I bought it, and that is why I can not re-code that option.
What I do not know is if they have "disabled" that option or "simply" no one has yet been able to figure out how to do it ...
      07-25-2017, 09:38 AM   #17
Almaretto
Almaretto's Avatar
2374
Not mutually exclusive, but option (with old coding) has been disabled and no one has come up with new working solution. I have no idea if all options have been exhausted.
      07-25-2017, 09:53 AM   #18
jaco_ma
jaco_ma's Avatar
Spain
28
Drives: G20 320d
We will not lose hope then.
If I find a solution, I'll comment ...
      10-15-2017, 11:19 AM   #19
jaco_ma
jaco_ma's Avatar
Spain
28
Drives: G20 320d
Anything new? Has anyone managed to activate it?
      12-13-2017, 03:51 AM   #20
jaco_ma
jaco_ma's Avatar
Spain
28
Drives: G20 320d
Still can not be activated?
      12-13-2017, 09:55 AM   #21
Almaretto
Almaretto's Avatar
2374
Call up BMW as they are the only ones that can give you reason.
      12-14-2017, 01:23 AM   #22
jaco_ma
jaco_ma's Avatar
Spain
28
Drives: G20 320d
The reasons for BMW to "get it" I do not know and obviously they will not explain it to me ...
The only thing he asked again was in case someone had found a way to activate it again.
A greeting
f30post
