05-02-2008, 01:01 PM | #1 |
Rep 5,069
Drives: BMW 230i Msport w/LSD
Location: Astral Projecting: ∞ 23.516 -122 02.625 0242.101 ĕv'rē-hwâr'
Garage List 2009 Porsche 911 997.2 [10.00]
2019 Hyundai N (Sold) [10.00] 2013 BMW M3 (Sold) [10.00] 2011 1M Coupe (Sold) [8.78] 2008 E90 M3 (Sold) [8.60] 2007 Z4 Mcpe (Sold) [9.50] 2005 BMW M3 (Sold) [10.00] |
Considering e92 M3 18's
I am thinking about putting 18" e92 M3 wheels on my car. Seems a bit aggressive at first glance, but not really compared to some setups I've seen with 10-15mm spacers. I am pretty sure the offsets I have input are all correct, if not please let me know.
05-02-2008, 01:40 PM | #2 |
Rep 5,069
e92 M3 18' on Mcoupe
I am a big fan of the new M3 18's. I am pretty sure they would look good, just don't know if they would work. Here is a quick photochop.
05-02-2008, 03:21 PM | #4 |
Rep 5,069
I dunno? that is about 3/4" out, but at stock hieght might be ok? I was hoping to get more feedback.
05-10-2008, 06:20 PM | #5 |
BMW Fan
11
Rep 553
The car's handling is a bit tricky at the limit already. Messing with the offsets like that may worsen that problem. It will look odd with the front wheels pushed all the way out to the very edge of the fender, or beyond.
There are plenty of great wheel choices for your car, why use something that will never be right even if you can manage to squeeze it on. |
05-21-2008, 06:38 PM | #6 |
Rep 142
I would love to see someone try this - I think it is doable but is extremely aggresive... throwing in some negative camber should help, as well as going with a 235 up front.
05-21-2008, 09:23 PM | #7 |
Rep 613
I get rubbing with a 8.5inch wheel with 225's and 35mm offset. This will definately cause rubbing in the front when the wheel is turned full lock. Plus I think it will stick out too far, might start to look ghetto.
05-21-2008, 09:53 PM | #8 |
My favorite sign.
167
Rep 4,333
I think as far as the cars handling near the limit is concerned...it's not that tricky...just keep the gas near the floor and she'll be have like you'd expect
I like the new M3 19s better...
05-22-2008, 05:55 AM | #10 |
Rep 142
This setup would definitely not require the use of spacers - spacers would make the problem even worse.
I know that there are some reps of the M3 19's that might work... The biggest issue of making understeer even worse would be that to even stand a chance at getting this to work you'd need 225's and would still want to have 275's in the rear. That big of a difference betweeen front and rear would make the car even more unstable at the limit.......
05-23-2008, 10:29 AM | #11 |
gone baby gone
382
Rep 1,052
Yah. The rears would fit a treat, but the fronts are NOT going to work for you, sorry to say. Spacers wouldn't help, they'd only make it worse.
05-23-2008, 11:03 AM | #12 |
My favorite sign.
167
Rep 4,333
I'm sure if you don't mind waiting...someone will make some reps that would fit.
05-23-2008, 12:05 PM | #13 | ||
Rep 5,069
05-23-2008, 04:11 PM | #14 | |
Rep 142
05-23-2008, 04:13 PM | #15 | |
Rep 5,069
07-24-2008, 09:57 AM | #17 |
Rep 396
OEM E90/92 18" tires would DECREASE understeer of M Coupe. 245/265 PS2 would be much better match than 225/255 PS. However, understeer is not entirely a bad thing. You want it just a tad bit...because it is easier to correct than oversteer.
Keep us post on what wheel you end up getting... |
07-24-2008, 10:23 AM | #18 | |
Rep 5,069
07-24-2008, 12:05 PM | #20 |
Rep 713
Drives: '06 E90 - '04 E85 - '16 F15d
I'm not sure what the difference is for the overall diameter for what you are consdidering, but based on your posted offsets you are moving the outer edge of the tire on both the front and rears less than one inch.
I put E92 18" rims/tires on my Z4 and moved both tires out by one inch with no problems with rubbing. Now, I know there are differences between ///M and non ///M cars but it seems like you should have no problem with the fit. As others have mentioned you may alter the handling characteristics, but after I changed mine the car drove BETTER and tire wear after 5000 miles appears normal. Good luck, I think it will look great. http://www.zpost.com/forums/showthread.php?t=94295
07-24-2008, 12:40 PM | #21 | |
Rep 5,069
07-25-2008, 05:45 AM | #22 |
Rep 142
