05-23-2017, 11:54 PM | #1 |
Rep 838
F30 LED Fog Light Stays Dimly On When Car Is Off
Just installed some new bulbs. Coded out the cold and warm checks and I can see the LEDs very dimly lit. I am not sure if they shut off after a while when the car goes to sleep but I am not sure what the issue is. My E90 never did this with any of the LED bulbs I put in
05-24-2017, 11:22 AM | #2 |
Rep 16,088
For whatever reason fogs require a resistor even with coding. Mine didn't stay dimly lit, instead they flickered at a very low intensity. Only the fogs, not the high or low beams. I added 15 ohm 50 watt resistors parallel to the fogs before the LED drivers, end of flickering.
05-24-2017, 09:14 PM | #3 | |
Rep 838
05-24-2017, 09:40 PM | #4 |
Rep 16,088
All the ones I've seen use 6 ohm resistors. Those suckers get hot, and stress the wiring, because a 6 ohm resistor at 12 volts burns 24 watts. I tested a few resistors, found that even 30 ohms stopped the flickering, went with these 15 ohm because they were readily available:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 They only drop 10 watts, so they stay cool and don't stress the wiring. Creating a harness isn't rocket science. I used these: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
05-25-2017, 08:26 AM | #5 | |
Rep 838
Edit- Set it up like this for each harness? Last edited by rich123321; 05-25-2017 at 08:36 AM.. |
05-25-2017, 09:42 AM | #7 |
Rep 838
05-25-2017, 11:51 AM | #8 | |
Rep 16,088
05-27-2017, 09:32 AM | #10 | |
Rep 838
05-27-2017, 09:38 AM | #11 |
Rep 16,088
Soldering is beyond simple.There's only one rule: heat the work, not the solder. If you heat the solder and drip it onto cold wire it won't bond. Heat the wire, then touch the solder to the hot wire.
05-27-2017, 10:15 AM | #12 |
Rep 193
I do not understand whats the problem of dimming you are talking about, can you please show us a video or sth?
i already coded and LED bulbs for the fog lights on mine and alot of other cars, removed flickering and errors. there are alot of various regarding dimming that we can play with, just illustrate for me whats ur problem |
05-27-2017, 02:38 PM | #13 |
Rep 16,088
There's no need for a video. For whatever reason there's a low level current going to the fogs even when the ignition is off. It eventually goes off, so it must be controlled by the same timer circuit as the auxiliary outlets. Depending on the specific LED/canbus driver configuration in some cases the fogs run at a low level, in some cases they flicker at a low level, and coding doesn't stop it, adding a resistor does. If you haven't experienced it then you're using different LED/canbus drivers than those of us who have experienced it.
Mwahab58.50 |
05-27-2017, 09:03 PM | #14 | |
Rep 193
Have you ever tried to play with dimming values? |
05-27-2017, 09:16 PM | #15 |
Rep 16,088
No. I only coded off the cold and warm checks and made LED active. It only does this with the fogs, not the headlights, nor the reverse lights, and since adding a resistor fixed it I didn't bother to investigate further.
05-29-2017, 02:27 AM | #16 |
Rep 838
Just an update, I built the harness using the parts you linked above. It was my first solder job ever and I am happy to report so far so good! I used some black RTV silicone to seal the exposed wires so it is drying overnight. Upon some quick tests using spare bulbs and pulling the wiring harness from outside the fender liner, the LEDs no longer appear to be dimly lit when the car is off and locked. After removing the built harness and plugging directly into the stock harness, the dimming returns! Will report back with final images tomorrow
06-04-2017, 08:43 AM | #18 |
Rep 16,088
07-23-2017, 09:26 AM | #19 |
Rep 45
Done.
07-23-2017, 10:04 AM | #20 |
Rep 16,088
If that's a 15 ohm resistor it probably won't get hot enough to melt that plastic tie, but if it's 6 ohm it will. Even though I used 15 ohm I bolted them to a metal tang that already had a hole in it, because the only way I'd find out that they got hot enough to melt plastic ties would have been after bad things happened.
07-23-2017, 11:27 AM | #21 | |
Rep 45
Thanks |
08-26-2021, 03:59 AM | #22 |
Rep 9
One little LED of the fog light is always on!
I have changed my f30 fog lights to f32 led fog lights and done the coding, there is no error on the car and also no flickering, but there is just one problem, one little LED of the fog lights is always one even when the car is off, as you can see in the picture. and in another picture I have shown the amount of light it has at night.
I was wondering is there any way to make this little LED off?! maybe by coding?! and If there is nothing I can do about it, doesn’t it drains the battry that i should worry about?! the coding i have done is this: FEM_BODY 3061 NSW_R_KALTUEBERWACHUNG -> nicht_aktiv : LED Foglights front right 3061 NSW_R_WARMUEBERWACHUNG -> nicht_aktiv : LED Foglights front right 3061 NSW_R_IS_LED -> aktiv : LED Foglights front right 3062 MAPPING_ABBIEGEL_R_PWM_LEVEL_1 -> 100% : LED Foglights front right 3061 NSW_R_UE_SPG_SCHUTZ -> dimmed : LED Foglights front right 3063 MAPPING_NEBELSCHW_R_PWM_LEVEL_1 -> 100% : LED Foglights front right 3061 NSW_L_KALTUEBERWACHUNG -> nicht_aktiv : LED Foglights front left 3061 NSW_L_WARMUEBERWACHUNG -> nicht_aktiv : LED Foglights front left 3061 NSW_L_IS_LED -> aktiv : LED Foglights front left 3061 NSW_L_UE_SPG_SCHUTZ -> dimmed : LED Foglights front left 3063 MAPPING_NEBELSCHW_L_PWM_LEVEL_1 -> 100% : LED Foglights front left 3062 MAPPING_ABBIEGEL_L_PWM_LEVEL_1 -> 100% : LED Foglights front left Last edited by Aria97; 08-26-2021 at 04:00 AM.. Reason: adding the pictures |
