05-18-2017, 05:20 AM | #1 |
Rep 2,022
Kombi Update required after NBT Retrofit?
Hi all,
So I've just retrofitted a NBT into my 11/12 F31. Coding wise - modified build date, added the VOs & coded the NBT & Kombi. NBT no issues with the NBT...... but with the Kombi I get this message on the NBT: Should I seeing this message, if not - does my Kombi (it's the basic cluster) really need updating with a build date of 11/12? Also, the Service History is still showing the donor cars details? Is this related to above? Any help would be appreciated. |
05-18-2017, 09:14 AM | #2 |
Rep 193
Never experienced it before.
you may try to VO Kombi with the same FA you coded NBT |
05-18-2017, 12:30 PM | #3 |
Rep 2,022
05-18-2017, 01:12 PM | #4 |
Rep 193
No with the FA u coded nbt with
05-21-2017, 07:50 AM | #7 | |
Rep 2,022
I have the basic Kombi and have coded it with the same VO I use to code the NBT. I've ensured KOMBI_CIC = kombi_low. The mode button on the steering wheel does nothing but the voice calling, tel & volume do. I'm not using a emulator - I had the fsc codes, so used a .bin file to activate the nav & voice calling. |
05-21-2017, 05:24 PM | #8 | |
Rep 8,364
Pay attention to dependency section. |
