E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Cosmetic and Lighting Modifications (exterior/interior) > HID Flickering
      05-08-2017, 10:40 AM   #1
aydan9879
Drives: BMW E90
HID Flickering
Hi all
Recently went to an HID Specialist shop to install HID's on my BMW E90 (2008). They fitted 6000k bulbs and upgraded my high-beams to Cobra bulbs.
However - when the keys are in the ignition and the car is started they flicker around 6 times.
I purchased a new canbus ballast only to find you cannot replace this with the kit they've supplied.
Any help would be greatly appreciated.
      05-08-2017, 10:42 AM   #2
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
Where are these lights fitted? Low Beam? Fog Light?
The flickering could be a bulb check or a weak battery - depending on the location.
      05-08-2017, 10:46 AM   #3
aydan9879
Drives: BMW E90
The 6000k bulbs are fitted into the low beams - but these don't flicker. It's the LED side lights and high-beams that do flicker.
      05-08-2017, 11:40 AM   #4
LED? Sounds like the bulb check flicker - which would be normal for LED's.
You can code out the bulb check if it bothers you. The car sends tiny pulses of electricity to check the bulbs to make sure they are working.
      05-09-2017, 05:17 AM   #5
aydan9879
Drives: BMW E90
I'll try coding out the bulb check on the high beam LED's and side light LED's tonight. Thanks Jeff
      05-09-2017, 11:29 AM   #6
There is a cold and hot check, so make sure you get both.
      05-11-2017, 06:01 AM   #7
aydan9879
Drives: BMW E90
Update - coding worked perfectly and was a very quick job. Thanks for the advice
      05-11-2017, 10:23 AM   #8
Awesome.
e90post
