05-03-2017, 04:06 AM | #1 |
Rep 153
Doubt: Lights when press close button once the car is already closed
Hi all,
When I press once the close button of the key fob with the car already closed, interior lights and door handle lights turn on. I would like more lights to turn on (front and rear fog lights, for example), because if you are looking for your car in a parking those lights may not be enough. There are a lot of info for welcome lights but not for this case, at least I found nothing. Could someone share the coding parameters to be changed, if possible? Thanks!!! |
05-03-2017, 08:58 AM | #2 |
Rep 16,086
05-04-2017, 12:25 AM | #3 |
Rep 8,364
If locking car, you are looking for follow-me-home.
If unlocking, you are looking for welcome lights. Alternatively, you can also use BMW ConnectedDrive App for remote features. |
05-04-2017, 01:38 AM | #4 |
Rep 153
Thanks, mates!
05-07-2017, 04:39 PM | #5 | |
Rep 153
I have been searching and testing this during the weekend and I think that there should be a third option or alternative: - Follow-me-home -> xenon on during few seconds after locking the car. - Welcome lights -> some lights on (depending on coding) when unlocking the car - "Searching lights" -> OVT (door handle lights) and interior lights on, when pressing the lock button with the car already locked. I would like to add more lights to this third option/alternative, if possible. Any clue will be highly appreciated! Thanks in advance!! Last edited by 00punisher; 05-08-2017 at 04:03 PM.. |
05-23-2017, 01:33 AM | #7 |
Rep 153
Hey, guys! Could anyone test this? Same behaviour?
As alternative, activating follow-me-home lights from key fob would be fine, but as far as I have searched, it is not possible in F3x... Thanks!!! |
05-23-2017, 09:40 AM | #9 |
Rep 740
As far as I know, the default method from BMW, follow me home is triggered by shutting the car down and pulling the high beam stalker will activate it for the preset time configured in iDrive.
Did my post help? Click "Appreciate!"
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD) |
05-24-2017, 02:13 AM | #10 |
Rep 153
Totally right, but in some Exx they can be coded to be activated from key fob, but it seems it is not possible in Fxx.
06-21-2017, 09:56 PM | #11 |
Rep 193
I will search and let you know.
06-21-2017, 10:41 PM | #12 |
Rep 193
While looking into your issue, i have found very useful parameters, which controls like literal everything.
time to start raising windows after pressing lock button FENSTERHEBER_FREIG_DELAY and FH_KURZHUB_DELAY_BEI_TUERE_SCHLIESSEN Disable Anti-pinch FH_MANUELL_MIT_EKS ----- For ( Remote Light) I didnt find any parameter for such thing, there isnt a parameter to control (which output lights when follow me home is triggered, or remote light is) search for this: CTR_FN_POLI , translate it, and see if there any clue. I have found different parameters, but they are all abou the duration, already spent one hour looking. |
00punisher24.50 |
06-21-2017, 10:43 PM | #13 |
Rep 6,003
You can also use connected drive to sound the horn if you lost your car in a parking garage as well as flash headlights.
00punisher24.50 |
06-22-2017, 12:55 AM | #14 | |
Rep 139
Every time I go to lock the doors and put up windows, I have to hold the lock down until all windows are up. I would like for it to be one touch and that's it |
06-22-2017, 10:02 AM | #15 | |
Rep 153
Mwahab58.50 |
