04-17-2017, 11:21 AM | #1 |
Rep 191
Drives: 2013 328i xDrive
Heated Sportline Steering Wheel - Don't need heat
I have a base steering wheel in my 2013 328i xDrive and may be purchasing a Sportline wheel with airbag - no paddles but has heat function. Will my car throw any error codes if I install wheel and the heat is not connected or retrofitted? I don't care about the heated functionality nor do I want to spend the cash on the retrofit parts.
'13 328i xDrive│Jet Black│BMS JB Stage 1│MPE│18" 400M & Conti DWS 06│DelVal BMW CCA #533245
04-17-2017, 11:29 PM | #2 |
Rep 166
The heat function has a separate connector so the car won't even know the steering wheel has that function. I did it on mine about a year ago and didn't get any errors.
(Well, I did recently get an airbag error but that's because the airbag connector got loose.) Kind regards, KingpinRCR |
obert1781.00 murphius1118100.00 |
04-18-2017, 06:43 AM | #3 |
Rep 191
Thanks for clarifying. I wasn't sure if there was a separate connector or not.
04-18-2017, 12:26 PM | #4 |
Rep 183
I confirm, i have the same configuration on my car and there is no issue as the heat cable are not connected.
