F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Update modules on Fxx
GetBMWParts
      04-17-2017, 10:08 AM   #1
TomaGo
TomaGo's Avatar
France
91
Drives: BMW X4
Hello,
I would like to update my BMW X4 F26 to the lastest firmware version for each module and have a few questions :
I have an Enet cable
1/ Is it better to use ISTA/P or E-Sys with Enet cable ?
2/ Can i update module 1 by 1 and avoid external power supply ?
3/ Can i update only motor (DDE) and Transmission ?
4/ How many time doest it takes for DDE for example ?
5/ Is it really risky ? (i did some coding with e-sys, everything is ok)
I have find this tutorial, did you allready test it ?
https://eobd21.wordpress.com/2016/09...520d-by-e-sys/
Thanks for your support
Thomas
      04-18-2017, 10:53 PM   #2
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
You need a external power source to update ECU's.
It is riskier than coding.
Both E-sys and ISTA-P work. You must use Expert Mode if you want to individually select ECU's in ISTA-P.
For updating, you need to check dependencies.
Time depends on software jump and which ECU's you are updating.
f30post
