BMW 5-Series (G30) Forum iDrive, Audio, Bluetooth, Phone, Cameras, Electronics + Coding HK vs B&W
      03-30-2017, 01:02 PM   #1
Laki021
Laki021's Avatar
Switzerland
367
Drives: BMW 540i xDrive
HK vs B&W
Has someone had a chance to hear both systems and compare them?
I known that price wise HK is a "better value for money", but if you are not happy with it that does not mean a lot...
I had a chance to try HK and I must say, something was missing, I was not impressed. In general I would be willing to pay the difference for BW if I would know that BW is the real thing.
I cannot find a car with BW to try, but what worries me is that the setup is not much different from HK, so not convinced that it would blow me out of the water as it should for that price tag.
So, if someone has experience with BW in G30 would be great if he could share a few words since it is practically impossible to find anything on this topic.
      03-30-2017, 01:45 PM   #2
MMY
Ireland
51
Drives: G30 530d M Sport Med Blue
Haven't heard the BMW version but there's a similar set up in the Volvo S90 (and €2000 cheaper option than with BMW!) ; quite a rew of the dealer demo cars had it installed here. Quite impressive but the value will be lost on the autobahn.
Current: G30 530D M Sport Med Blue/Cognac
Previous: F10 530D M Sport Plus Sophisto/Ivory
F10 520d M Sport, F30 330D M Sport, 2 x F10 520d, 2 x E 60, 2 x E 39.....
      03-30-2017, 02:12 PM   #3
Eric500
um...
Eric500's Avatar
413
Drives: LC500
I know it doesn't mean much, but I thought the hk was better in the g30 than my f10 and the BO in the 2018 s5 I test drive earlier today.
The Audi does not have an equalizer either
328i -> 535i -> X5 -> 540i -> Lexus LC500
      03-30-2017, 02:21 PM   #4
54Me
Drives: 2013 X5
Not really a definitive sampling of reviews, but certainly seems like the 7 owners are glad they have it... if not just for the fancy speaker grills...
http://www.7post.com/forums/showthread.php?t=1319791
      03-30-2017, 03:33 PM   #5
steve090619
Drives: bmw 540xi
Harman Karmon is great. the Logic 7 equalizer probably wasn't set. spend some time adjusting the equalizer and sound will change dramatically.
SDRX204.00
      03-30-2017, 05:10 PM   #6
G30
Drives: G30 540i xdrive
Yes I have heard this also, I also opted for Hk, used the money for the BW for other options. I think it's a smart move
      03-30-2017, 10:50 PM   #7
X6DB
Drives: 2024 M4 Comp xDrive
Not sure about B&W, but the B&O system in my f10 M5 was very definitely worth the extra money. Balanced, clean sound at all volume levels; the sound quality does not fall apart, even when you play it loud.
      03-31-2017, 12:16 AM   #8
pharding
Drives: 23 Audi Q4 e-tron + 14 X3 28i
I heard the B&W system in a new 7er. It sounded absolutely amazing. A notch better than my 2014 B&O System. However I went with the HK system because it was a better value.
23 Audi Q4 e-tron; 23 i4 M50 on order
14 X3
Retired: 20 Tesla Model 3 LR AWD; 17 540i x; 14 550i Euro Del; 11 550i Euro Del; 08 550i Euro Del; 06 330i Euro Del; 04 545i Euro Del; 01 530i Euro Del
      03-31-2017, 04:47 AM   #9
cerbera
Drives: 540i xdrive M Sport
I have HK in my current F10; I (and my teenage son)listened to the B&W on an unregistered G30 in the dealers, who then loaned me a G30 with HK for a day.
The HK in the G30 is noticeably better than in the F10 - better clarity, better placement. The B&W was amazing - even to ear bleeding levels - with better bass extension, great feeling of sitting in a concert hall. The lights in the door tweeters are annoying.
But, in normal use, with the car moving, the HK is going to be close to the B&W; given the massive price difference, I stayed with the HK - and used the money saved for some other useless toys!
G30 540i xdrive msport
retired :F10 535d msport 2014 : F10 535d mSport 2010:E60 535d mSport 2006: E60 535d mSport 2004:E39 530i 2001:E39 528i 1997
      03-31-2017, 05:43 AM   #10
Laki021
Laki021's Avatar
Switzerland
367
I guess you can switch of the lights.
So there is a clear difference between HK and BW, but with proper EQ settings HK might be pretty good solution as well...
      03-31-2017, 05:48 AM   #11
cerbera
Yes, should have said the HK was pretty good as well...I tweeked the equalizer to be the same as in my F10...
      03-31-2017, 01:02 PM   #12
54Me
Drives: 2013 X5
I would say that this option is less about affordability and more about your desire to have what is clearly the "best" audio option (I am taking knowledge of B&W reputation, the positioning from BMW, and some limited reviews at face value to make this statement).
If it causes a question with affordability, or you have to sacrifice other features that are more important to you to get this, then you should not be considering it.
I spent many years as an audio installer, and have put $5,000-$20,000 systems in otherwise crappy cars, so the idea of $4,200 doesn't phase me on that level. Read the article in the BMW Magazine, and if it doesn't make you look forward to it like a kid on Christmas then don't buy it. Could I be disappointed?... Sure, but I won't regret it.
Below I put the B&W into the lease calculator to give you an idea of what you will really be paying. Note that I put the cost of the HK into the rebate field since you would have to pay that anyway if you are comparing B&W to HK.
If $24 a month is too outrageous to take a risk on, then don't do it. I'm not sure you are going to find enough information prior to your buy decision that will make it an purely objective decision.
Good luck.
      03-31-2017, 01:58 PM   #13
ThreethirtyDee
I've ordered HK
I'm not a audiophile so could do with some help to set it up properly.
Can you post a picture of the settings you use please. I know it'll depend on audio source and type of music but would like something to build from..my car arrives on Thursday
It's a bit like my TV, hundreds of options for picture settings and I'm not sure where to start
Thanks
Need to change name to FivethirtyDee
ZigmundUK443.00
SDRX204.00
      04-29-2017, 08:45 AM   #14
GhostWorks
Drives: F07 530D SE GT ( 2010/07 )
I've ordered the B&W system for my G31, can't wait...
I did test a G30 with HK system wasn't that great but the idrive has so much potential now with Flac etc and can hear the difference between CD and Flac, So thats why i went B&W as well as the only peace i get to listen to music is in the car rather than home etc ( better than getting high end system at home )
For me anyway
      04-29-2017, 10:06 AM   #15
VZehn
VZehn's Avatar
Drives: 2014 BMW 540i
I had the B&O in my F10 and it was astonishing. I could crank the decibels up so high that my eyeballs rattled and my vision blurred. However, the B&O system had one major fault - AM radio was unlistenable. It was like listening to someone from the bottle of a well.
I tend to listen to some talk, news, and sports radio here in Chicago on AM. And so for that reason (and value) I went with the HK in the G30. I have not been disappointed - it's excellent! Overall sound quality is very, very good across all media types. And while it won't rattle your eyeballs like the B&W might, it has no problem handling your favorite music with clarity at volumes you could get pulled over for.
2017 540i xDrive Carbon Black/Canberra Beige
former beasts: 2014 M5 CP Black Sapphire Metallic / Silverstone; 2006 M5 Black Sapphire Metallic / Portland
      09-09-2017, 05:39 AM   #16
Ryno 27
Drives: M5 Competition, X5 M50i
I don't know what to do... to order or to not
      09-10-2017, 05:38 AM   #17
nsa100
Drives: G31 540i & G30 540i M Sport
I have ordered the B&W system for my G31, without hearing it,even in a 7 series. My car will hopefully arrive in 1-2 weeks so I will try to give a review.
I had the B&O system in the F11 I had and it was very good, so I can give a direct comparison. (Although the system will need running in for a few weeks, to fully appreciate the bass)
I also upgraded my 2014 M5 which has the HK system by adding Bavsound speakers including the Ghostsubs as another reference.
I did listen to the HK system in a new G30 and found it better than the standard HK system in my M5 and on par with the Bavsound Speakers, with smooth treble and reasonable bass, even on the move.
Hope that gives you some insight.
      09-14-2017, 03:58 AM   #18
morellomax
Drives: 2022 M440i xDrive convertible
[nsa - have you kept the Bavsound speakers ? Worth swapping at least the front mids and tweets across if you can. Rear door mids won't fit on G30 - they foul the door card, also the dash tweeter on G30 is the same as the door tweeters rather than oval plate, but everything else will fit.
(G30 HK + Bavsound) is slightly better than (F10 HK + Bavsound) I think, and defintely better than just (G30 HK).]
IGNORE - just spotted you've ordered B&W.
Last edited by morellomax; 09-14-2017 at 03:59 AM.. Reason: didn't read your post properly
