BMW 5-Series (G30) Forum iDrive, Audio, Bluetooth, Phone, Cameras, Electronics + Coding Coding!
      03-21-2017, 03:48 AM   #1
ZigmundUK
ZigmundUK's Avatar
Drives: I20 IX M60 Oxide Grey
Coding!
Hi all.
So who's got any coding planned? What are you going to do? And also how do you do it with this car?
I know in previous models one had to plug in the laptop with a special cable and software. I saw something on YouTube about just using a USB stick or something. What's the crack with the g30?
Running: G30 530d M Sport (B57) Mediterranean Blue
Running: I20 IX M60 Oxide Grey
Gone: F15 X5 40d M Sport (N57) Glacier Silver, E61 520d SE Auto (N47D20) Titanium Silver, F31 330d M Sport (N57D30A) Estoril Blue, E87 120d SE Auto (M47TU2D20) Sparkling Graphite
      03-25-2017, 04:50 PM   #2
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Originally Posted by ZigmundUK View Post
Hi all.
I have coded two so far.
Fxx-/Ixx-/Gxx-series vehicles all use ENET cable and E-sys software.
The same kinds of things can be coded as on previous models, but more are standard from factory.
      03-31-2017, 11:23 AM   #3
AP
AP's Avatar
2777
Drives: G30 M550
dobyou happen to know if indicators can be enabled in the HUD (via KOMBI)
have this on my F10 which I find very useful.
      03-31-2017, 11:05 PM   #4
Almaretto
Almaretto's Avatar
2374
I have it on my F015 & F010 as well.
Traditionally, certain HUD coding like turn signals cannot be enabled on DKOMBI (Digital 6WB instrument cluster). Though the G030 & G012 have a different ECU than that of the 6-series, I have not actually attempted to code.
      04-11-2017, 12:11 PM   #5
M6BMWDriver
M6BMWDriver's Avatar
Drives: F12 Singapore Gray M6 Conv
Do you know where to change the speedlock on the rear and front cam, it used to be on PAM or PDC. but I don't see it on the G030 anywhere?
      04-11-2017, 12:14 PM   #6
Almaretto
Almaretto's Avatar
2374
Did you check iCAM?
      04-11-2017, 12:20 PM   #7
M6BMWDriver
Did you check iCAM?
I did, but I'm getting nothing in there.
Something is not being read correctly. In iCam i have bunch of junk not like the other modules. Like 3000 ., FC and so on.
I can't get the BDC_BODY2 to read coding data either.
I'm getting an error file for cafd_......., not found [C012]. I used pro launcher with version 3.27 and 3.28
And i have the full PSdZData
What do you think is wrong.
      04-11-2017, 01:44 PM   #8
Almaretto
Almaretto's Avatar
2374
Out of curiosity, why do you want Cameras at all speeds? The coding disables distance and speed auto-shutoff so then you manually must toggle a different screen.
Full Psdzdata is a waste of space (80 GB) unless you are planning to flash program. For coding, all you need is one Lite version (2 GB)
Are you using Pro Launcher 2.7.1? iCAM should look like this:
      04-11-2017, 04:00 PM   #9
M6BMWDriver
I'm using Launcher Pro V2.6.1.130
Maybe thats why!!
Will i need a new activation code from TM if i install the new version?
      04-11-2017, 04:10 PM   #10
Almaretto
Almaretto's Avatar
2374
Maybe thats why!!
No. You will not need a new activation code. 2.6.1 should have same mapping as 2.7.1, the ladder has some additional optimization. Link never changes, so you can download and install update.
      04-11-2017, 05:41 PM   #11
M6BMWDriver
Thank you, all updated. Still no luck. Oh well!!
      04-11-2017, 05:43 PM   #12
Almaretto
Almaretto's Avatar
2374
You do not see iCAM like I posted in #8?
      04-11-2017, 08:05 PM   #13
M6BMWDriver
Yeah no luck, it doesn't look like it at all. I will try to put everything on another laptop and see what happens.
      04-13-2017, 02:09 AM   #14
Almaretto
Almaretto's Avatar
2374
Strange. How about if you load files in NCD / CAFD Tool?
      04-13-2017, 07:54 AM   #15
M6BMWDriver
I tired that and still looks funky. But all the other ones looks good.
      04-13-2017, 12:08 PM   #16
Almaretto
Almaretto's Avatar
2374
Can you post screenshot? I do not understand what you are seeing.
      04-13-2017, 10:47 PM   #17
M6BMWDriver
here you go. let me know what you think?
I just think It's not reading the ECU correctly because on the header the ecuname is blank on the module.
      04-14-2017, 12:29 AM   #18
Almaretto
Almaretto's Avatar
2374
CAFD_0000207C is unmapped on my system too. I also seemed to have missed that ECU in my recent CAFD_ID PDF update.
      04-14-2017, 01:07 AM   #19
M6BMWDriver
Uhhhhh... Nice work!!! I thought i was doing something wrong, i gues this is a 2017 so maybe BMW AG did a new update.
Oh well I'm glad you know why it's not working!!
      04-14-2017, 01:31 AM   #20
Almaretto
Almaretto's Avatar
2374
The rest of your ECU's should map. I have not seen car yet with ATM2 or iCAM4.
      04-14-2017, 02:52 AM   #21
HawaiiG80Green
Drives: 2017 M2
Which main series do i chose to code on the g30?
      04-14-2017, 01:11 PM   #22
Almaretto
Almaretto's Avatar
2374
S15A psdzdata covers F090/G001/G002/G011/G012/G030/G031/G032/RR11/RR12/RR31
