F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > USA - New England > BMW Airbag warning light..Diag, fix and clear fault codes
GetBMWParts
      03-19-2017, 04:36 AM   #1
Bmw4lifejoc
Bmw4lifejoc's Avatar
Drives: E92 335i
Airbag warning lights are usually faults that occur within the airbag module , crash safety, Srs, systems.
The OBD 2 scan tool was able to diagnose the issue down to the seat belt pre tensioner, which is part of the SRS safety restraint system.
A seat belt pre tensioner is a device that is used to hold a passenger firmly in their seat just before and at the start of a collision (especially in a front or head on collision) and then allow that passenger to come into contact with the inflated airbag in a controlled way.
The video shows step by step, removal of the seat, unplugging SRS wiring harness and removal of faulty seat belt buckle (female)(right) passenger side. Then installation of new buckle then plugging SRS wiring harness back together and eventually bolting back the seats. In conclusion, showing a final Diag and clearing up the airbag warning fault using the OBD scan tool.
I hope this video helped someone, and Thanks for watching -Raoul Jacques
      06-25-2018, 05:53 AM   #2
Nomana
Nomana's Avatar
1466
What brand and version of the scanner in video?
Can i use it for my 2014 F32?
      06-25-2018, 03:10 PM   #3
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
Why put this in the New England forum? I'd share it with everyone.
      06-25-2018, 03:20 PM   #4
IK6SPEED
Drives: BMW M3 / AH3
Well, the pretensioner are part of the SRS but have nothing in common with Airbag, so not sure why you labeled and posted that way.
The pre tensioners have an explosive that triggers to tighten the seatbelt during an incident. They can trigger without the airbags ever going off.
In fact, prodogs had it happen recently.
http://f30.bimmerpost.com/forums/sho....php?t=1504657
It’s easy visually check if the pretensioner has fired (besides a warning on dash and CID) by simply looking or feeling the end of the pretensioner for an exposed cable.
But again, has nothing to do with airbag.
f30post
