Cracked Trim, Fix Before Wrapping?
03-09-2017, 03:57 PM | #1 |
Rep 17
Hello, I am preparing to wrap my interior trim with Avery brushed steel. My trim has cracks in them now. Do I need to repair them first before I wrap them so the cracks will not show through? Or can I just wrap it with out any worries. Please let me know.
Thank you, Liem |
03-09-2017, 04:02 PM | #2 | |
Rep 204
From what I have seen if the cracks are big enough (even hairline ones) it will be visible under vinyl wraps. |
03-09-2017, 08:21 PM | #3 |
Rep 17
Yea that is what I figured. I have tried looking for a while on how to repair cracked interior trim. But I usually come up with how to remove.. how to plastic weld.. how to wrap.etc. Can someone please help point me in the right directions. Would really appreciate it. Thanks.
03-09-2017, 09:12 PM | #4 | |
Rep 4,202
Drives: '11 335is | '16 Macan Turbo
'11 335is BSM MT "BMW Performance Editon" | '16 Porsche Macan Turbo
GruppeM CF Intake | AR Resonated DP | ER CP | Turbosmart RacePort BOV | Cobb FMIC | RB Inlets | RB External Mishi/Turner OCC | Michelin PS4 | BMW Performance Springs/Bilstein B8 + Dinan & M3 bits | BMW Brembo BBK | BMW Performance CF Spoiler | BMW Performance CF Lip | BMW Performance Alcantara | PS Designs GTS Armrest | AG H6-40 | Rear Seat Delete |
03-10-2017, 04:36 AM | #6 | |
Rep 229
Fill the crack with some JB weld, give it 24 hours to dry and then sand it down to conform with the rest of the trim piece before wrapping, job done.
http://www.e90post.com/forums/showthread.php?t=1245727
Instagram: @joelzsantana |
03-15-2017, 09:42 PM | #7 |
Rep 947
If the crack catches your nail when you go over it, it will show. If not, it probably won't.
I would get a small section of vinyl and just place it over the crack, leaving like 2" per side. You'll be able to tell if the crack comes through. |
03-16-2017, 02:17 AM | #8 |
267
Rep 2,741
I have dealt with many types of 3M vinyl material. And I'll share one of my thoughts.
I had brushed aluminum trim. With many dents and scratches. If you use gloss black metallic vinyl from 3M it's very thin and will show imperfections over your existing trim. Using gloss black it's a little thicker and coverage is better than gloss black metallic. Using brushed black aluminum or any brushed type coverage is excellent against dents and scratches. Carbon fiber vinyl is a bit more thicker than brushed and you won't even tell if you had scratches or dents. |
triax37130.00 |
