FS: ??? N54 Downpipes | *cut-up* JB4 S2+FF N55 Harness A | *bent* BMS N55 DP & CP
03-04-2017, 11:51 PM | #1 |
2143
Rep 1,836
Drives: Many, BMW.
N54 Downpipes - No clue what these are, VRSF v1? v2? anyway, they were dull/matte silver, sprayed them in high-temp black to inspect for damage and appear to be in good shape - I checked the fitment by fitting them back on upon removal, and didn't have any troubles, however... I already had the engine pulled. - $230 ------------------------------------ ------------------------------------ Following are removed from a smacked up early 2012 135i - parting out btw, DCT / Black Int / M-Sport ------------------------------------ OEM N55 Intake MAF Sensor - $60 ------------------------------------ BMS N55 Downpipe - Appears to be buckled right past the downstream o2, can always be used for custom catback. - $80 ------------------------------------ BMS N55 Chargepipe - Throttle body side is in good shape, so is the rest of the pipe, except at the IC side - see photos. - C-Clamp not included, but can be for an extra $20. - $80 ------------------------------------ BMS N55 JB4 Stage 2 (Harness A) w/ FF & OEM N55 ENGINE HARNESS - showed up cut, FDNY thought they saved the day? Eitherway... I began to resolder it back together, but my soldering iron is sucking it easy, so I'll pass the fun onto someone else. All the wires are there, wastegate plug got crushed, so I'm including whatever is left of the N55 engine harness (which has all the plugs you need + more) to finish repairing this harness. - $240 Last edited by Igor_M5; 03-24-2017 at 01:10 PM.. |
03-18-2017, 10:12 AM | #3 |
2143
Rep 1,836
Drives: Many, BMW.
To the top.
03-24-2017, 01:11 PM | #4 |
2143
Rep 1,836
Drives: Many, BMW.
Price drop.
