02-24-2017, 09:49 AM | #1 |
Rep 107
Rust marks coming out from alloy wheel centre
After driving in the wet I get rush marks coming from the centre of the alloy.
Any ideas/advice? Car is only 3 months old, been doing it since new.
2016 320d M Sport LCI
02-24-2017, 09:55 AM | #2 |
Supreme Being
1804
Rep 5,425
Crappy BMW rusty hubs - they come as standard on all models.
Current: F90 M5 Competition
Gone: F80 M3 Competition Pack / M135i / F15 X5 M50d / Saab 9-5 Aero HOT / F30 335d xDrive M Sport / E92 LCI 320d M Sport / E46 320d M Sport Touring / E46 318i Touring |
02-24-2017, 09:56 AM | #3 |
Rep 1,060
Rust from your hubs, take wheels off clean up the hub and apply some copper slip grease around the hub refit wheels, won't have a problem anymore and will aid removal of wheels in the future.
G15, 840i M Sport
02-24-2017, 10:06 AM | #5 |
Rep 798
Mine does this too with the 442Ms. Have flagged it to the dealer twice - they've simply taken off the wheel and cleaned it up. Don't imagine that will actually cure it though.
Current: 21 G21 330e | Portimao Blue | 791 M | M Sport Pro | Vis/Tech/Comfort Plus packs
Previously: 19 F20 M140i Shadow Edition | EB II || 16 F31 340i | EB II || 13 F31 330d Luxury | MG |
02-24-2017, 10:30 AM | #7 |
Rep 13,043
Drives: BMW M340I G20
Bit of copper grease on the hub spigot helps no end.
Current car.M240i. Previous.MINI JCW. E92 325i. 435d M235i.M135i. 635d Coupe, E92 M3 manual, E92 M3 DCT Competition Pack. E92 335i, Porsche Cayman S Gen2, 135i Coupe. E92 320d, MK5 R32. MK5 Golf GTi,MK5 Golf GT-TDI,E46 318Ci. |
02-24-2017, 10:46 AM | #8 |
King of the North (living in the east...)
1056
Rep 2,155
looks pants doesn't it...
2021 M340i in mineral white, options galore
Previously 2018 440i GC in MG 2015 330D F30 MSport EBII 2012 Alfa Guilietta 2.0d Veloce 2009 Fiat bravo sport 2000 ST Mondeo |
02-24-2017, 10:52 AM | #9 |
Rep 1,060
Either way rust coming from hub or disc top hat but I have the M sport brakes which has an alloy cover as a top hat and I had the same rusting marks on 442 alloys, once greased no further problem.
G15, 840i M Sport
02-24-2017, 10:57 AM | #10 |
290
Rep 2,598
When you wash your car, remove the centre caps and dry out the hubs. Or get a blower and blast them dry! None of my cars has ever done that, as I always dry them out...!
Will also aid alloy wheel life too and the dreaded centre lacquer peel... |
02-24-2017, 01:02 PM | #11 |
Rep 834
Do you use a pressure washer to clean your wheels?
BMW X1 sDrive20i ///M Sport MHT
02-24-2017, 01:07 PM | #12 |
Rep 404
02-24-2017, 06:42 PM | #13 |
Rep 7,032
Drives: 335xd Msport +
It's a known issue.
Had it on my previous and current f30. Took it back to dealers both times and they rust proofed and greased the end of the internal hubs - never happened again Funnily enough was on the loaner I had whilst getting mine done.
02-25-2017, 12:15 PM | #14 |
Rep 1,705
I had this on my rear wheels 442's after a few weeks of owning from new. They weren't as bad as yours though.
BMW photographed the hubs and asked for authorisation to fix. They were only authorsed to remove rhe wheels and grease the rear hubs. However, I haven't had anything since and it's been over 12 months now. |
02-25-2017, 12:22 PM | #15 |
Rep 1,705
My dad has an Audi Q3 that had silver painted hubs from new. It is less than a year old with 2,500 miles and the rust has come through the paint and looks terrible. It's down to the cast iron material of the disc/hub that just rusts. BMW doesn't look as bad as there is an alloy hub/spacer behind the wheel where as Audi just have one lump of cast iron that is the disc and hub.
02-26-2017, 12:15 AM | #16 |
Rep 3,664
BMW used to fit plastic caps on the hubs to stop this but have stopped in the last 12 months (probably cost cutting)
Order 4 of these (part number 33406864028), Clean out the hub centres and grease. Fit plastic caps and it will never happen again
Current: M4 G82
Past: C43, X4 M40i, TTS, M4 CP, 440i, 435d, M235i, 220d, F30, E90, E87 |
